car starts and stalls after 3 seconds
Old Mar 8, 2012
Levi22's Avatar
Levi22 is an unknown quantity at this point
03 Civic Lx 5speed manual trany, 1.7 L, car starts but dies 3 seconds later. Battery ok, apparently the fuel pump work ok, ignition switch ok, apparently fuses ok, still wonder how should I had done this check ups. Some I tested with the Hondas repair book others by what I read in the internet. I'll check the timing belt today so I'll find out whether it is out of time. But I wonder why it would be out of timing. althought some time ago I notice a smell of burning plastic, I wonder if this happened in the timing belt, we'll see. Any help, pls? car has been in my house 3 months.
Old Mar 25, 2012
Juanma1980cr's Avatar
Juanma1980cr is an unknown quantity at this point
Re: car starts and stalls after 3 seconds
Hello Levi22.
Have you checked the fuel pump relay? The smell to burned plastic and the fact that the engine dies after some seconds makes me think about that possibility. I hope my comment helps.
Old Mar 25, 2012
First: Got codes? That would be a good starting point.
3 possibilities come to mind...
A) When it dies is the green key light flashing? Immobilizer problem.
B) Alternator bolts loose.
C) Unplug the cam position sensor and see if it runs longer than 3 seconds now. If it does then shut it off at 5 seconds and tear off the front of the engine, the cam is out of time by one tooth or more and you have a serious problem that needs figured out ASAP.
The burned plastic smell makes me think C will be your answer. Is there a clattering noise that goes along with this?
HTH
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
dragonsblood
Apr 27, 2015 12:28 PM
McD
Apr 22, 2015 05:28 PM
Blaster30
Apr 22, 2015 12:21 PM
McD
Apr 16, 2015 10:46 AM
