1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
motor questions..
Old Feb 19, 2012
troy9520's Avatar
troy9520 is an unknown quantity at this point
motor questions..
my 94 ex has had a motor swap to a d15, and i want to put a frankenstien motor in it, so i was just gonna put either a b16 or b18 heads on a ls block. does the d15 have an ls block? and are there any suggestions as to what else i could do that would be alot better than my d15? im not looking to spend a ton of money
Old Feb 20, 2012
89slowcar's Avatar
89slowcar is an unknown quantity at this point
Re: motor questions..
b16 head will not fit a d15 block to my knowledge. b16 is twin cam and d is sohc. so it is not compatible.
yo can get a y8 head which will give you vtec and a lil more hp. you can pick em up cheap too. for your price range thats the best way to go
Old Feb 21, 2012
troy9520's Avatar
thanks, but i really wanna switch to dohc, what would be the best and most affordable way to do that?
Old Mar 10, 2012
89slowcar's Avatar
well you would have to swap blocks and trans and exhaust header too. im not 100 percent bout distributor but th rest will need to be b series. non vtec b18 are cheaper than the rest and you can find vtec b16 or b18 heads and make it work. also your car has a hydro trans so make sure you find a hydro or know the cost and labor of swapping cable in car or the converter that bolts on trans. not many cheap ways to do a b swap lol. but you can freshen up your d and turbo it.
Old Mar 10, 2012
02civicsi02's Avatar
Low and slow!
If you wanna go dohc and fairly cheap you can pick up a zc motor and swap it in. It's the higher compression d series which is the d16z6 basically. If you wanna go with a frank build I suggest a b20 block with b16 head. Or even k swap the thing with a k24/k20 frank lol
jdawgzcivic
17
Feb 1, 2020 04:16 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
khatib
Sep 9, 2015 10:50 PM
FistRock
Sep 4, 2015 08:00 PM
hatch90
Sep 3, 2015 08:45 AM
