How do you use change rear turn signal?!?!
Old May 1, 2002
RSXtypeIvtec's Avatar
Su Mo
I tried putting the new bulb in place of the old one like regular bulbs...but no...dont fit
then i tried pulliing the old bulb out of that little black holder piece and then trying to replace the new bulb into the black holder....
but no that didnt work cause i couldnt get the old bulb out!!!
so now i dont even know how to change it the proper way??
The manual was confusing....so now i come to you all
Please help!!
i have no left turn signal
Old May 1, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
have you tried your local automotive store (pep boys, NAPA, NOPI, etc.), most of the carry the entire assembly for the rear turn signal.
Old May 4, 2002
Su Mo
why are you all telling me where to get the bulb from??
i dont recall asking where you get it from?
i said if anyone knew how to change it, i already have the bulbs!!!
Old May 4, 2002
Machina's Avatar
Machina is an unknown quantity at this point
hmm...it is so easy I really don't know what to say...umm. I know you probably made sure the bulbs were the same part number, the only thing I can tell you is to twist the assembly counterclockwise, pull it out, put a kleenex overtop the bulb and pull straight out...you don't want to touch the bulb with yer fingas...then do the reverse with the new bulb...try it out...
Old May 4, 2002
Su Mo
but there is a black holder on the bulb, do i have to pull the bulb out from that??
cause its not coming out for some reason??
Old May 5, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
No, the bulb is in a black holder. The replacement bulb you hace should have an identical black holder, which you put into the place where your old bulb's black holder was.
Old May 5, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
Instructions are in the owners manual [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
blackbullet
Dec 1, 2001 03:44 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
