8th Gen 2006 - 2011.
Key fob does not open passenger doors
Old Feb 13, 2012
slemon's Avatar
slemon is an unknown quantity at this point
Hi everybody, new guy here. I was happy owner of 2006 Honda Civic LX sedan until recently. I noticed that I cannot open passenger doors with key fob. I can do it from driver's door using door lock switch. Another thing that my alarm goes off when I start the car.
I searched and can't find topics about it.
Old Feb 13, 2012
Re: Key fob does not open passenger doors
If I had to take a WILD STAB at it, I'd be inspecting the lock actuator in the drivers door first.
Here's why: If the position switch inside the actuator is bad, then the MICU doesn't know the drivers power lock moved from lock to unlock, so it keeps trying to unlock the drivers door every time you hit the remote. It has to see the drivers door unlocked before it will try to unlock the rest of the doors. That would explain the alarm going off, too.
A wiring diagram and a volt/ohm meter could easily prove or disprove this theory. Could also be a wiring problem.
Old Feb 13, 2012
slemon's Avatar
Hmm, sounds interesting (not really). Could it be moisture inside the door? I stumbled at one service bulletin regarding doors not opening but nothing about alarm though.
Old Feb 13, 2012
The door is designed to get wet inside it.
Wouldn't matter anyway. If moisture in the actuator switch was the issue, then the unit isn't sealed and is bad anyway.
You can speculate all night and never solve the problem.
Test, don't guess.
Old Feb 13, 2012
slemon's Avatar
and it doesn't matter that I can unlock doors with driver side unlock switch? If actuator was bad then unlock switch wouldn't work either or would it?
Old Feb 14, 2012
Different circuit, different command inside the MICU. Yes, it should still work normally.
And the switch I'm talking about is only one part of the lock actuator. The lock actuator MOTOR still works fine.
Old Feb 14, 2012
slemon's Avatar
So would I replace switch or the actuator assembly? Any diagrams or pictures you can direct me to? Sorry I'm just starting to dig into this thing.
Old Feb 14, 2012
You're on your own for wiring diagrams. I can't hotlink my info.
Here's a parts catalog pic, looks like it comes as part of the door latch. #19.
Pretty cheap, considering what it is.
http://www.hondaautomotiveparts.com/...-+OUTER+HANDLE
Old Feb 14, 2012
slemon's Avatar
thanks
h4ldol
Jun 3, 2015 03:26 PM
Billybob1963
May 31, 2015 07:37 PM
beveragemp
May 25, 2015 07:11 PM
Laurenhunter7
May 10, 2015 01:09 PM
Killagi
Apr 12, 2015 10:42 AM
