1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 Si and 90 DX, how compatible
Old Feb 3, 2012
DragonHawk's Avatar
DragonHawk is an unknown quantity at this point
I picked up a 1989 Si with a Y7 motor installed as a parts car for my 90 DX. The plan was to pull body parts off the Si to clean up the DX but with the Y7 motor and the over all body condition of the Si, I am tempted to got the other way now.
The main problem with the Si is suspension, CV's, bent wheel hub. On visual inspection all the parts look interchangeable for the DX to the Si. Are they the same front ends underneath?
The first step will be to swap out the knuckle/hub and driveshaft on the passenger side as one unit if this will work.
Thanks for any input.
Old Feb 19, 2012
89slowcar's Avatar
89slowcar is an unknown quantity at this point
Re: 89 Si and 90 DX, how compatible
the axels are a little bigger on a si. but if you change it all, it will bolt. is the y7 running?
Donahue
Sep 8, 2015 09:00 AM
Amulon
Aug 18, 2015 11:03 AM
Snax
Aug 12, 2015 10:23 PM
