Brandons SKUNK2 Powered Mugen SI
Old Jan 28, 2012
myreasontoshame's Avatar
myreasontoshame is an unknown quantity at this point
This is my SKUNK2 Powered 08 Mugen that I got a little more then a year ago. Only 1,000 produced. Check out the Video links at the end of this. BTW this is all just the beginning there will be a lot more to come.STILL NEEDS TUNE WAITING TILL AFTER WINTER
Scroll Down For UPdates
Mod List
AEM CAI
Igallas ETD
Mishimoto Oil Catch Can
FlashPro
Boomba Motor Mounts
Skunk2 Black Series DBW Throttle Body
Skunk2 Pro Series Intake Manifold
Skunk2 Composite Fuel Rail
Skunk2 MegaPower Header
Skunk2 MegaPower Type RR 76mm Cat Back Exhaust
Skunk2 1.3 Radiator Cap
Skunk2 Black Series Billet Battery Tie Down
Skunk2 Black Series Billet Oil Cap
Skunk2 Billet Shifter
Skunk2 Magnetic Drain Plug Set
Skunk2 Brake Res. Cover
Skunk2 Billet Shifter ****
NST PULLEYS
Mishimoto Radiator
Mishimoto Shroud And Fan
Mugen Quick Shifter
Skunk2 Certified Serial Number 0001
Here it is when I first got it.
Stock
But shortly after having it I wanted to start working on it.
So first I went with a AEM CAI
Then I did
Skunk2 Proseries Intake Manifold
Igallas Engine Torque Dampaner
Hondata FlashPro
Then I did a couple of little things
Skunk2 "Go Faster" License Plate Frame 2x
Then i Did
Skunk2 MegaPower Type RR 76mm Cat-Back Exhaust
And heres what it looks like now
And To where Im at now
Boomba Motor Mounts
Yes I know I have to Igalles ETD as well but i had that before I went to Boombas and the
only reason why I Still have it on with my boombas is because i think it look pretty cool
And soon (within this month)
NST Pullies
Mishimoto Radiator
Mishimoto Fan And Shroud
Update 7-29-11
Skunk2 Billet Shifter (on its way pics soon)
Skunk2 Magnetic Drain Plug Set (on its way pics soon)
Skunk2 Brake Res. Cover (on its way pics soon)
Update 8-2-11
UPDATE: Parts Showed up today
Installing Aug 15th
Update 8-8-11
Update 8-16-11
Got my o2 sensor completly finished
Installed the Skunk2 Shifter ****, Skunk2 Brake Res. Cover, Skunk 2 Magnetic Drain Plugs, and My Skunk 2 Certified Badge
Mugen Quick Shifter Install
Mishimoto Radiator & Mishimoto Shroud and Fan Install
Mishimoto Radaitor
HONDA TYPE 2 COOLANT
Size:  185.7 KBCross Member out.
Radiator Shroud and Fan Out
Harness That Needs to Be Cut off the Stock Shroud and Fan..
and Crimped or soldered to these blue to red and black to black
Crimped together also I wrapped it with Electrical Tape just no pic of it
Mishimoto Radiator & Mishimoto Shroud and Fan Installed
Cross Member Back on
Looks awesome... Fairly simple install... When i was running the car i was tightening a couple more bolts on the crossmember and the fans turned on scared me a lot louder and faster then the stock fans. Way more noticeable over stock if you put your hands behind the fans.Still Left This Winter To Install
NST Pulleys
TUNING when i bring it back out after Winter
Here are some of my Videos
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1173& transactionid=1327780358-5081192122&posted_by=myreasontoshame_www.civicforu ms.com&youtube_video_id=WEm9vUbLKJw[/autostream]
Here is a couple of videos of it on a Dyno At King MotorSports Dyno Day 2011
This run was 208 whp with a nonProfessional tune I had them do two Datalogs so i Can tune
very soon and hopefully see some bigger numbers I just want to wait until i do my pulleys
to do the tune.Which i should be ordering within the next month.
Heres the pic of the Dyno Chart
Thanks to "flyby" for this video.
Im Also gunna Paint my Valve Cover.
BLACK or FUJI BLUE PEARL(to match the color) lets get some feedback.
Thank You Everybody
Majarvis
Aug 19, 2013 07:11 PM
flipryde
Sep 10, 2005 10:11 AM
sivikchik
North East
Apr 14, 2005 08:57 PM
PicCoLoboi02
Feb 2, 2005 04:51 AM
