08 civic AC bearing replacement
Old Jan 15, 2012
mhayek's Avatar
mhayek is an unknown quantity at this point
My car went into a ditch and engine went partially under water. I changed oil and filter, tranny fluid, replaced alternator cuz it got wet. Works ok but I hear a "whir" from the right side of engine and my guess is the AC compressor bearing. Dealer says $250 for clutch/pulley/bearing assembly. Can I pull pulley and press out/replace bearing? I see ebay has OEM (NSK) bearing for $30 but before I buy it I wanted someone with knowledge in this area.
Old Jan 15, 2012
Re: 08 civic AC bearing replacement
It isn't real tough to get the pulley off to replace it if you have the tools and know what you are doing. It can be a bear if the compressor has a lot of age and corrosion on the hub though.
I don't even have to discharge the system to replace the clutch set. I do it all with the compressor still attached on most. Occasionally I have to unbolt the compressor for access, but I try like hell to do the work without having to discharge the system.
But I have never tried to change ONLY its bearing.
Pull it off, take it to a press, try it?
The worst you can do is ruin it, and you already needed the new one.
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 07:11 PM
jessicakaybby
Apr 20, 2015 12:11 PM
thesushiboy
Apr 12, 2015 02:54 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
