transmission issue 3rd gear
Old Jan 13, 2012
kal1fornia's Avatar
kal1fornia is an unknown quantity at this point
hey guys, so i have a problem with my 3rd gear. When i'm driving around normally 3rd gear works fine with no problems, it goes in and out fine. however when im pushing it and i'm changing into 3rd lets say at 6500 rpm its really hard to get it into gear and i have to push on it quite hard to get it in. however today i was coming home from work and when i went to try it again, it grinded when i tried to put it in 3rd. however still when i'm just crusing around in goes in and out of 3rd no problems. the car currently has 101k miles. so i'm thinking either the clutch or the syncro for 3rd gear is going bad...any thoughts guys would be much appreciated!
Old Jan 13, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: transmission issue 3rd gear
Year make model of car?
fluid levels good??
Old Jan 13, 2012
kal1fornia's Avatar
2003 civic si, and just changed the fluid to redline MTF, and it was doing it before i changed the fluid
Old Jan 13, 2012
SOUNDS like the blocker ring (the brass ring, part of the hub and synchro set) is either worn out or broken. One would need to do a complete teardown to find out.
Honda has an improved part for this, this is copy and paste from the service information I found: Honda Service News, Nov 2004
"Are owners of M/T-equipped ’01–05 Civics or
’03–04 Civic Hybrids complaining of gear grinding
when shifting from 2nd to 3rd or from 4th to 3rd?
A new carbon-coated synchronizer 3rd gear set
from Honda parts stock is just what the doctor
ordered. Ask for P/N 23444-PLW-315,"
Not from a Honda, but a ring example:
(That person should be wearing blue gloves...)
Cracked/broken ring:
Old Jan 13, 2012
kal1fornia's Avatar
I doubt that theres broken parts in there, because like i said, when i'm driving normally its fine and there is no grinding at all. but yea, i was afraid of it being a syncro/blocking ring. and it even explains to more that you provided that quote from honda service news. sounds like its that for me, i hardly ever downshift so next time i drive i'm going to try downshifting from 4th to 3rd. i'm guessing because it doesn't grind when i'm driving normally that its not too worn down but it definitely is at least a little bit for it to be so hard to get into gear. by chance, any clue on how much it would cost to get the tranmission rebuild with the transmission already out? i could take the tranny out myself but i don't want to rebuild it lol
Old Jan 13, 2012
No clue. Call your local and ask BEFORE you start anything. You might check with transmission shops too.
Research your choices thoroughly. I wouldn't trust just any flunky to do any trans work.
Good chance they won't provide any warranty on the job either, since they didn't diagnose it or do 100% of the work. I know I wouldn't want to because I can't control the work YOU do.
jackshepardjr
May 24, 2015 09:53 PM
cruisers10
May 12, 2015 10:46 PM
markp94
Apr 30, 2015 09:19 PM
Jeeves
Transmission
Jan 31, 2002 08:37 AM
skywalker
Jan 23, 2002 03:00 AM
