2011 Civic oil leak
Old Jan 11, 2012
Niceandeasy's Avatar
Niceandeasy is an unknown quantity at this point
Question 2011 Civic oil leak
2011 civic base model. I went to get my wifes oil changed at the dealer and they told me the car had a leak. 40,000 miles and a oil leak wtf and they told me its a 100 buck charge to look for it. But the leak is on the back side of the motor and its high. I need help picking out what it can be. Looks to me like the intake is two parts and where they meet its got oil. but i never seen a intake having oil in it. so i need help picking out what it maybe.
Old Jan 11, 2012
CraigW's Avatar
Re: 2011 Civic oil leak
5 years 60k miles warranty should cover this, no ?
Maybe the valve cover needs tightening ??
Old Jan 11, 2012
5/60 warranty (USA). End of story.
Call the 1-800-customer assistance number?
Find a better dealer?
Old Jan 12, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
^i agree..take it to the dealer tell them to fix it under warranty..if they say no go to a diff dealer and file a complaint...
Old Jan 12, 2012
they said if it bolts on its not coverd. the next dealer is over 2 hours away.
Old Jan 12, 2012
That's wrong. It's leaking engine oil.
If it is what I'm thinking of, it's covered. End of story. See below.
Whomever you have been dealing with needs some "re-education".
(I would) Call the customer assistance number and see what they have to say about it. Be courteous, be professional, but be firm. Use the info below, use the proper part name and have the part number ready so they can check for coverage.
Catalog link:
http://www.hondaautomotiveparts.com/...PAN+%281.8L%29
Unless I miss my guess,
The leak SHOULD be coming from the "breather cover", #9.
It needs resealed. Not replaced.
It's been one of the more common leaks on these engines since 06.
We cover it under the 5/60 powertrain warranty.
Unless my guess is wrong, then I need more info.
I ran the part number in the powertrain warranty inquiry, this IS covered 5/60 here. I assume it SHOULD be the same everywhere.
Old Jan 13, 2012
CraigW's Avatar
^^ ezone, How would you access it for the repair ??
Old Jan 13, 2012
On a hoist, not laying on my back in the driveway.
I'll look more later, gotta clock in now.
Old Jan 13, 2012
Hope this link works (PDF)
http://www.google.com/url?sa=t&rct=j...SZZPHfoHMvh5HA
Please note this bulletin does NOT apply to the car in question, but the method is the same.
Wish I could see the OP's car to see where exactly it is leaking. Regardless, any engine oil or trans fluid leakage should be covered under the powertrain warranty.
Old Jan 13, 2012
04 Honda Civic's Avatar
Why do you need to remove the right axle what am I missing?
Old Jan 13, 2012
Look under one of these cars, you'll see why.
I don't normally remove the axle, but I have lots of cool tools to get around it. Most people don't have quite the selection of tools that I have accumulated over the years.
Old Jan 16, 2012
Greg_Elite's Avatar
Greg_Elite is an unknown quantity at this point
They shouldn't charge you crap since it's under warranty.
LionSpratt
Jan 29, 2017 11:07 PM
C6GrandSport
Apr 25, 2015 09:41 PM
