Ignition...key pls!
Old Jan 7, 2012
brazor's Avatar
brazor is an unknown quantity at this point
Ignition...key pls!
My ignition has been acting up. When shutting of car it doesnt release key (eventually does). Anyone else had this?
Old Jan 7, 2012
Re: Ignition...key pls!
Does it not turn all the way to LOCK?
If it does turn all the way to lock, does it not release the key?
Which?
Got a less worn out key to try? Try a new key that wasn't duped, have it cut by the key code. Might just be a worn out key.
Old Jan 7, 2012
brazor's Avatar
Yup. Happens when key turned to lock. Do keys really go bad?
Old Jan 7, 2012
Does that mean you can or can't turn the cylinder to LOCK? Your answer wasn't clear to me.
And yes, keys wear out. Just grind all the teeth flat on one and try your locks.
Old Jan 7, 2012
Here ya go, check this out: http://www.justanswer.com/uploads/Ho...005918_zzz.pdf
Old Jan 7, 2012
brazor's Avatar
Thx everyone!
