How to install Power Windows? 2001 Civic DX Coupe
Old Jan 6, 2012
Civic19's Avatar
Civic19 is an unknown quantity at this point
Hello, I apologize if there is another thread similar to this but I've been searching the entire forum but I just couldn't find a helpful thread regarding this.
I was wondering if there's a DIY for this as well but I just couldn't find it.
I found a 2002 Honda Civic EX Coupe at a nearby Auto Wrecking center and I saw that the door panel linings and powered regulators are still intact. Since I was already there I thought maybe I should take this opportunity to take parts needed to replace my roll up windows to powered ones but I'm kindof unsure if it's possible. If it is then what parts should I take out from that donor car?
Questions are:
Do I need to replace both driver side and passenger side entire door panel linings if I want to use OEM power window regulators?
Is it better to use those OEM powered window regulators or is it better to just use Universal Power Window kits with their own switches?
What is the most correct way to wire them and make it work?
The things that bother me is how to mount those switches.. How to wire correctly.. and does the window glass mount perfectly on both manual and powered regulators or those universal power kits?
Help please, I'd really like to make this work.
Here is a honda parts link to my vehicles exact model catalog & diagrams:
http://estore.honda.com/honda/parts/...-5mt&dl=208485
2001 Honda Civic DX Coupe Door Windows Diagram:
Above shows 2 regulators, the one on the left should be powered right?
2001 Honda Civic DX Coupe Door Lining
Old Jan 6, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: How to install Power Windows? 2001 Civic DX Coupe
There is a DIY here but it is for a universial kit... I do not know the answer to most of your questions and for that i am sorry..the wiring should be about the same for the OEM stuff and this DIY... I hope it helps..
http://reocities.com/SouthBeach/palms/6531/ click power windows
Old Jan 6, 2012
GolNat's Avatar
Prelude Owner
For your wiring go to your local parts store and get a Haynes manual for the 01-05 civic. I have one and it has all the wiring info you would need along with how to take everything apart.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
mj1010
Aug 26, 2001 09:52 PM
