01 LX Coupe aftermarket keyless entry install.
Old Jan 2, 2012
Arceneaux's Avatar
Arceneaux is an unknown quantity at this point
I've installed a half-dozen car alarms in my life without issue, until now... I wanted to add keyless entry to my car, so I picked up a basic system. The Avital 2101L. I've got everything hooked up perfectly, except I can't get the doors to lock and unlock?! The lights flash, the horn honks, the led comes on, but the locks don't work!
I've t-tapped into the white/blue and white/green wires behind the drivers kick panel, but I can't seem to figure out which wire to hook up.
Here's the wiring breakdown for my system: (ignore the last column)
http://www.the12volt.com/installbay/...tion_table.jpg
Any help would be appreciated
Old Jan 2, 2012
boyd117's Avatar
boyd117 is an unknown quantity at this point
Re: 01 LX Coupe aftermarket keyless entry install.
Are you using the common output pin 30 to connect to the car wires and obviously connecting pin 87 inputs to ground? The door lock wires should be in a gray plug above the drivers kick.
Old Jan 3, 2012
Arceneaux's Avatar
No I hadn't. I'll try this after work tonight. I guess I figured the system would use the black ground wire...
Green/black to white/blue
Blue/black to white/green
Violet/black to ground
Violet to ground
Thanks for the help!
Old Jan 3, 2012
boyd117's Avatar
Let me know how it turns out
15EXCoupe
Jul 30, 2015 12:59 PM
Nalmonte
Jul 22, 2015 09:08 AM
bizspeed
Florida
Jul 14, 2015 08:40 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
