02 civic cel on for o2 sensor
HI, I Have a cel code p0141 on my 2002 civic lx body with ex engine. With no cat on the car. How can I get the light off in my car. With out butting a cat on my car.
Re: 02 civic cel on for o2 sensor
P0141: Secondary Heated Oxygen Sensor Heater Circuit Malfunction.
That is not a cat code. A cat code is P0420.
The PCM cannot test or set a cat code until this code is gone.
Once this code is solved, then the PCM can test and fail the cat monitor.
I don't understand why all you kids think that having a cat is a bad thing.
Live for the Twisties
You can remove the 02 sensor code without installing a cat and sensor by getting k-pro -$1100.
Just get a cat, adding 0.1whp by removing it at the cost of the environment is childish.
you might ask a mechanic if it is possible to install an 02 sensor socket on the bypass pipe and screw in an oxygen sensor in there and plug the other end into the harness if it's still there. But even if you do something like that to fix the P041 code, the P0420 will pop up if it's not already there. The best fix is to install the cat and the sensor back in or live with it like that. do you have state inspection in your area ?
JetsterDajet
52
May 8, 2016 12:11 AM
jdh022764
18
Nov 3, 2015 06:44 AM
pfwel1977
Sep 10, 2015 02:16 PM
dantheman42
Sep 4, 2015 01:10 PM
