New clutch, need to replace/refinish flywheel?
If I'm having the clutch replaced in my 2003 Civic, should the flywheel be refinished or replaced as part of that job?
I found one DIY guide that emphasized the need to refinish the flywheel at a shop or replace it, but that's not been mentioned in the quotes I've received so far.
Re: New clutch, need to replace/refinish flywheel?
Rule of thumb is to resurface the flywheel or replace it. I like to compare this to pads and rotors. If you're just replacing the pads, you'd need to turn the rotors so the pads have an even surface to seat onto.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
beanhead
Sep 24, 2015 12:04 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
