Eld problem
Old Sep 26, 2011
Hooper_Sir13's Avatar
Hooper_Sir13 is an unknown quantity at this point
Eld problem
I have a 2002 Honda civic sir and i have the code for my eld sensor voltage high
but recently my radio and cluster have been dying for a split second and coming back also once my car almost stalled i was wondering if these 2 things are connected
Old Sep 26, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Re: Eld problem
Are you blowing any fuses?
Could be the voltage regulator on the alternator going bad. The voltage could be fluctuating...going too low then too high.
You will need a new alternator to fix it if this is the problem. If it's the original 10 years is a typical lifespan.
Old Sep 27, 2011
Re: Eld problem
did you try replacing the eld in the fuse box? they sell just the eld by itself.
Old Sep 27, 2011
lazlong's Avatar
Re: Eld problem
Part # 38255-S5A-003. Ask for that part specifically, otherwise they're try to sell ya the whole fusebox @ $250.
Old Sep 27, 2011
Re: Eld problem
i checked mine today and it looked pretty burnt. i wonder if they have a certain lifespan but i guess the engine light would come on if it stops working.
Old Sep 27, 2011
lazlong's Avatar
Re: Eld problem
Man, almost forgot. Make sure you put the plug for the ELD back in the right spot as there are 2 spots it can go into. Been there, done that. Spent $28 needlessly, now the extra one just sits in the closet till this one goes bad.
Old Mar 14, 2013
ragerianES1's Avatar
ragerianES1 is an unknown quantity at this point
Re: Eld problem
Wat does the eld do...im havn a problem wer my orange lights i.terior and brake lights do not turn on with my headlight switch...but wen i hit my pedal or turn signal they work...any ideas? I noticed this happend after i installd my sidemarkers..possibly bad wirei.g job? Shoot some help
Old Mar 14, 2013
Re: Eld problem
2003 es1
MiniMi
May 27, 2015 01:57 PM
jackoncruzpr
May 24, 2015 12:24 AM
tattedlariat
Apr 20, 2015 09:26 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
