install window channel run honda civic 2001
Old Sep 15, 2011
mgabra2's Avatar
mgabra2 is an unknown quantity at this point
I am trying to install the window channel run (Part Number B 13--on the very left--on this image http://parts.sonshonda.com/images/pa...ize/971566.png). Is the a DIY??? It seemed simple, but now I'm not so sure! I'm having issues with the ends of the channel run extending into the door itself. Do I have to remove the door to install the window channel run? Thanks!
MG
Old Sep 16, 2011
CraigW's Avatar
Re: install window channel run honda civic 2001
Is it tight as can be top and upper sides ? Will the window go up properly ?
Old Sep 16, 2011
mgabra2's Avatar
The reason I want to replace this part is because the one I have now is defective and is interfering with the ability of the window to scroll up. Yes, the window is able to scroll up. However, it is starting to make a noise as it scrolls up, and I am afraid the window engine-thing is going to break.
Old Sep 16, 2011
CraigW's Avatar
Do you have the new insert in place yet, or still the old one ??
For the noise check that your rubber insert is properly in place in the lower metal channels. If it is an old insert you might try cleaning real well upper and lower and give it a try.
Old Sep 16, 2011
mgabra2's Avatar
The issue is the channel run is interfering with the window scrolling up. I can see the channel run getting in the way of the window. It is not a fixable problem, as the channel run is badly misshapen.
Old Sep 16, 2011
CraigW's Avatar
Is your car a coupe or sedan ??
The illustration is not a 2001 door ( not sure if it was just a reference picture)
Old Sep 16, 2011
mgabra2's Avatar
It's a sedan
Old Sep 17, 2011
CraigW's Avatar
Both the 7th and 8th gen manuals show the "glass run channel" but neither shows a procedure for replacement.
I would say it just gets pressed into place.
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
liljoe
Nov 4, 2001 01:27 PM
