Guages/Cruise Not working
Old Aug 16, 2011
scott_howe87's Avatar
scott_howe87 is an unknown quantity at this point
Exclamation Guages/Cruise Not working
2002 Honda Civic LX 4-dr
I've searched and searched for what could be the reason for my problems and I can't seem to find for sure what the issue would be. My speedo, tach, gas gauge, heat gauge have all stopped working. At first it was intermittent but now they are all but dead. And when one went they all went. Also the backlight in the gauge cluster doesn't work. And the tripmeter and odometer also go out when the cluster isn't working. However the check engine light and other warning signs continue to function correctly. Also the cruise doesn't work.
The previous owner did a lot of bad working to this civic trying to make it "nicer". However I have torn this dash apart countless times and can not find any shorts or broken wires. There is a green (approx. 12 pin) plugin under the dash that I cant seem to find a place to plug in, is this normal?
Otherwise, might my cruise and gauge problem be connected?
Is there are relay blown I just can't find?
Bad VSS?
Bad cluster?
Ty
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
