Critique my compresson test results?
Old Aug 10, 2011
Rexspeedmaster's Avatar
Rexspeedmaster is an unknown quantity at this point
Did a compression test today, 2003 civic ex, 160k
1: 185
2: 195
3. 195
4. 200
I then added a small bit of oil to the cylinders through the spark plug hole, and retested (I have heard this is a way to detect piston ring failure.)
1: 210
2: 220
3: 210
4: 225
Backstory,
I have been losing coolant with no visible leaks. I am thinking that it is the headgasket, however after this compression test I am not sure what to think?
I drained the coolant and oil and there was not visible mixing of the fluids. It seems that my coolant is just disappearing.
The car will only overheat after 2+ hours of highway driving, and even then only when I slow down or just idle. The fans kick on with the ac, so I know they work.
I'm starting to think a possible thermostat issuse? or bad water pump maybe?
Any help would be appreciated.
Thank you.
Old Aug 10, 2011
Re: Critique my compresson test results?
compression test is not the way to go. when i had a small gasket leak and burning thru coolant, the compression test showed normal all were around 200psi +/- 10psi. if you are losing coolant and it disappears without a leak, chances are very good there is a small leak that seals up once the engine warms up. i never had any overheat or white smoke, nothing. but the coolant would keep disappearing and i did see some white deposits on two of the plugs. and sometimes a minute of misfire when cold starting the car. thermostat and water pump wouldnt cause those problems (unless waterpump is leaking coolant). you could try a combustion gas test on the coolant to see if its contaminated. and if you open the radiator cap and the coolant bubbles constantly for over 30 mins, its def a small gasket leak.
Old Aug 10, 2011
lazlong's Avatar
Classic symptom of a bad headgasket. Sorry bro.
Old Aug 11, 2011
I bought the car recently and was planning on changingthe gaskets, seals, and belts anyway so it's not to huge of a deal. My main concern was that I would replace the headgasket and still have the problem. I'll change it Out and see what happens.
Old Aug 11, 2011
when you change the gasket out, make sure and take the head to a machine shop for cleanup, testing, and milling the bottom for a straight edge. otherwise yes if you just replace the gasket it will leak again for sure. most shops (like carquest machine shop) only charge around $100 for "the works" on a head to get it ready to install.
Old Aug 11, 2011
Bustitsideways's Avatar
Bustitsideways is an unknown quantity at this point
no its either waterpump or thermostat, you may have a leak from one of the hoses, hows the condition on the hoses?
Old Aug 11, 2011
BlueEM2's Avatar
Whachya lookin at?
You can check all the hoses and stuff but 99% it`s the head gasket.
carid
Nov 7, 2015 01:46 AM
OptimisticWay
46
Oct 15, 2015 02:16 PM
EngiNERD
Aug 9, 2015 08:28 PM
DerbyDad03
Jul 27, 2015 11:34 AM
Jul 12, 2015 11:54 AM
