wipers not parking at regular spot
Old Jul 5, 2011
alex.w *//'s Avatar
alex.w *// will become famous soon enough
so the wipers work, when i turn the switch on, and it goes up and down fine, but why does it park half way of the windshield?
is the motor broken?
03 civic sedan
Old Jul 5, 2011
marccayen's Avatar
marccayen is an unknown quantity at this point
Re: wipers not parking at regular spot
What do you mean by park half way up the windshield? All it might need is a little adjustment but maybe a little more detail on this park issue may help.
Old Jul 5, 2011
alex.w *//'s Avatar
it goes up and down like regular when its operating.
but when it parks or when i turn off. it stop at the middle of the windshield
Old Jul 5, 2011
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
If you mean you're turning off the car while they're wiping, and once the car is off they just stop on the middle of the windshield and not finish their last wipe then it's normal. Turn the wipers off then the car off
Old Jul 9, 2016
leosar's Avatar
leosar is an unknown quantity at this point
hi
i have the same problem,when i switch off the wipers switch not the car, they don't park in the regular spot,and i have to give on/off(wiper switch)to reach the regular spot.
any suggestion
thanks
Old Jul 9, 2016
leosar's Avatar
hi
any suggestion
thanks
Old Jul 9, 2016
I might take the wiper motor out, take the cover off the end and see if the park contact strips have worn out or fell out. Plan on replacing the motor?
Old Jul 9, 2016
leosar's Avatar
thanks for the reply
how to take the motor out?
thanks
Old Jul 10, 2016
thanks
Remove fasteners, remove motor.
You may want to get a service manual.
If the park position contacts inside the motor assembly aren't damaged, then regular electrical testing should ensue as per the service manual.
RSJ
Aug 13, 2016 01:06 PM
jpandjf
Aug 3, 2015 05:02 PM
cyc
Jul 22, 2015 01:14 PM
mokkush
Jul 14, 2015 04:05 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
