2001 Civic HX has two CVT drain bolts?
I spoke with the Honda parts dept and they told me that the CVT has TWO drain bolts? Is this true and if yes, where's the other bolt? I'm only aware of the obvious, easy to locate one.
Re: 2001 Civic HX has two CVT drain bolts?
Best thing to do would be to get your own manual so you know for sure and don't have to rely on other people. Best advice I can give ya. Good luck.
A descendant of 2k1civic.com
I'm not 100% sure. I don't have an HX. However, if I were to guess there is probably a drain bolt and a fill bolt. I can't think of a reason why there would be 2 drain bolts. Definitely check the manual, or ask the guy why there are 2 drain bolts and see if he gives you a good reason.
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
