No radio signal / reception .... please help
Hi guys,
I am having problems with my radio signal / reception. When I bought the car, I had the OEM radio and I didnt get any signal / reception. I was thinking that there was something wrong with the OEM radio, but I bought an Alpine headunit, I installed it and made sure that the antenna cable was correctly connected to the back of the alpine headunit. However, I still have no signal / reception. FYI cds, ipods and everything else works great... I just dont get any radio sigal / reception.
Do you guys have any ideas how to fix this problem or what to do?
Any input will be appreciated
Re: No radio signal / reception .... please help
The antenna is right above the rear window heater. See if its not damaged. Its the lines on the rear windows it self that looks different from the lower half. They have too connect some where to wires but don't really know where.
Edit: Iam not sure if the antenna is in side the glass with no way of damaging it or if you could fell them like the defrost ones from the inside. Either way it will be hard to figure out if you have all connections flush all the way in.
Thanks for the input, I will check for that first thing tomorrow morning. Also I will check to see if there is a fuse for the radio antenna.
More ideas are welcome
See if the antenna wire came unhooked behind the radio.
1. Look below the center A/C-radio panel for 2 screws and remove 'em.
2. The whole panel just pops out toward you. You will see the antenna plug.
You can check continuity(Ohms) with the multi-meter to see if the lines on the window are actually working.
step 1:
2. Unplug the power wire from the little prong attached to the window
3. Set the meter to ohms. Then place 1 probe on the prong and one probe on each line painted on the window in turn to find the bad spot.
Also, check continuity of the wire from the radio to the window.
To fix the line painted on the window:
1. Get some metallic antenna paint.
2. Carefully scrub the area with steel wool. Then clean with alcohol.
3. Carefully tape off above and below the line
4. Paint on a thick coat and let dry for at least 30 minutes.
5. Apply second coat of paint and wait at least 3 hours before removing tape.
6. Test for continuity.
Sorry about the fuzzy pic, crappy phone cam.
step 1:
I think the antenna is not inside the glass.
step 1:
step 1:
I will need to buy a multi-meter.
If anyone has more ideas what to check or how to fix it please advice
My understanding is that some cars with the antenna amp in the trunk have several connections and do require power. (if you do not have a roof antenna)
There is a connection at the back of the stereo which you already connected and there should be another one behind the passenger kick panel.
Also make sure that you hooked up the power antenna wire from the stereo to the antenna amp in the wiring harness. You should be able to test power at the antenna amp with a volt meter.
**UPDATE **
So I finally have the volt meter, and I was ready to do all the test. I am on the back seat so I removed the covers to both sides of the rear window. When I removed the one on the passenger side I saw the wires from the antenna and also I saw a small amp which is the ANTENNA AMP (as TIGGERDX mentioned). The wire was not connected to the ANTENNA AMP so I connected it and the problem was solved.
Thanks to those who replied to my question.
hello there..im having the same trouble..cant get a better reception on my stereo..so i was trying to do same as you...how can remove the covers from both sides of the rear window? thanks
**UPDATE **
The antenna AMP is on the driver side so you just need to remove that one.
Hope this helps
I actually did the power cables on either side and non had better reception over the other. still have the problem, at least i know its not the powercable over the antenna cable.
robjcivic
Mar 12, 2017 12:10 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
