1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
best vtec engine?
Old Jun 9, 2011
SoNeZter's Avatar
SoNeZter is an unknown quantity at this point
Unhappy best vtec engine?
I just got a 1995 civic and i want to put a vtec engine on it but ive heard theres like b16 and b18 etc... i was wondering which one would be the best one for my car? im new at this so i would really appreciate some help
Old Jun 9, 2011
MindBomber's Avatar
Live for the Twisties
Re: best vtec engine?
You need to do some research on your own, you'll find lots of info on engine swaps and realize you could swap to a vtec head for a couple hundred dollars or drop in a k20a or b18c5 for $5000+
Old Jun 10, 2011
02civicsi02's Avatar
Low and slow!
You definetely need to do some research cause there are tons of info on this, but the b series have the most fierce vtec kick but the k series has the best vtec cause its ivtec plus it has something vtec doesn't and that's vtc. Putting a b series in your car will cost bout the same as a k.
But you still gotta know that you can simply just swap on one of the d series vtec heads on yours and it will be cheaper and easier but the decision is yours.
Old Jun 10, 2011
SoNeZter's Avatar
and is there a serial number or where can you find out what kind of vtec is it?
Old Jun 17, 2011
diversity210's Avatar
diversity210 is an unknown quantity at this point
Depends on what you are going for really. The 5 gen civics and Si's came with a D16Z6 vtec engine which is acutally the engine with the least power out of the vtec's but it seems to be the most sought after when it comes to a simple upgrade and rebuiled.
The D15B is a little harder to find than the D16Z6. This engine offers higher compression with increased horsepower and torque and has a 3 stage vtech head. Gives you about 5-10 more horsepower of the Z6 engine. Companies actually make more street legal turbos for this engine that the Z6
B16A is also a vtech engine. Dual Over head cam engine, but you are getting into a little more technical know how with this swap and a lot more money. Most sell these anywhere from 1200-2300 depending on what they come with. tranny, axles, ECU, wiring harness. Still a fairly easy swap, but does need a little more no how than a D series swap. Good thing about this engines is they will offer you quite a bit more horsepower over the D series engines. These engines are also a lot easier to turbo, because they require less of a rebuild to safelly run about 14psi. A simple replacement of the pistons with GSR pistons and your good for turbo.
The B18C is going to be by far the most expensive of the B series engines. These things are hard to come by and are pretty expenve costing you around 3200. The B18C is going to run the most power of all the other engines that I have mentioned.
Now if you have the money, the patients, the time and the determination then you can opt to swap a K series into the car. Very popular swap these days and even easier now seeing as companies like Avid and Hasport make the mounts for it. Still a bit of a complicating and technical builed though and for this one you are going to need some dough. This is not a budget builed, but when it is done you will have a beast of a car.
MamaBear2015
26
Apr 16, 2015 11:08 PM
Grey
16
Jan 27, 2002 11:34 PM
AznSaint
Jan 8, 2002 12:58 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
BamBam
Dec 8, 2001 02:21 PM
