ex engine misfire
ex engine misfire
need some help. my 2003 civic ex has started to run rough pulled codes only codes are p300 thru p304 it seems to misfire under low rpm(1500 rpm's and under) any common failures? where do I start? thanks for the help
Re: ex engine misfire
I will pull the plugs and check the coils today but it doesn't seem logical that all 4 plugs would go bad at the same time to cause all the cylinders to misfire I was thinking a sensor problem or fuel pressure issue but I will start with the basics first
oh, good, i was not sure how much you knew of cars.
try to search the codes in the site and in here:
http://www.obd-codes.com/trouble_codes/honda/
thana
Jun 15, 2020 07:05 PM
danace99
23
Jun 28, 2015 08:49 AM
zaboomafoozarg
May 30, 2015 09:21 AM
davidarenberg
May 16, 2015 08:45 AM
Blaster30
Apr 22, 2015 12:21 PM
