Interior water leak when raining?
Old Apr 19, 2011
T355's Avatar
T355 is an unknown quantity at this point
On the driver side a-pillar, where the headliner meets the plastic pillar cover, there is a leak where water is dropping in and onto my seat. It only happens when the car is parked and it is raining for a good while. I just washed my car and it didn't leak in. So it seems to take a while until the water starts dripping in. Also it doesn't drip when I am driving. I have visually examined all seals around the top of the door and all seem to be fine. Has anyone ever heard of this problem and if so what was the fix?
Old Apr 19, 2011
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: Interior water leak when raining?
Lift up the rubber that is between your metal roof and the glass of your windshield so you can peek underneath it. If it's all rusted that could be your problem. Just had mine sandblasted and the guy said he was surprised it wasn't leaking already. Costs like $250 to have done if that's your problem.
Old Apr 19, 2011
T355's Avatar
That's what I was thinking I should do. If I pull that rubber up will I be able to just push it back down into place again? Or will I have to buy a whole new piece since i pulled that one up?
Old Apr 19, 2011
jponto07's Avatar
jponto07 is an unknown quantity at this point
The rubber weatherstripping is reusable. Be sure to clean both the weatherstripping and the mating surface with acetone or something similar to ensure that the new adhesive sticks well.
Something to consider is removing the extra adhesive from the channel under the weatherstripping. When I did mine, there was extra adhesive that squished out of the mating surface between the windshield and the A pillars. I was unable to put the weatherstrip back without cutting it out.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
ashlava71
May 16, 2015 12:54 PM
silvervtec01
Dec 9, 2001 08:50 PM
Importracer
Nov 4, 2001 07:50 AM
