Key stuck in ignition in 1998 Civic
Old Apr 18, 2011
chillin21's Avatar
chillin21 is an unknown quantity at this point
I have a 1998 Honda Civic EX and I accidently put my 1992 Honda Civic key in the ignition. Now the key is stuck in there. I don't know how it went in so easily, but now I can get it back to the "OFF" position to get the key out. Any suggestions for DIY?
Old Apr 18, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: Key stuck in ignition in 1998 Civic
Here's a diagram of the key cylinder (from hondapartsnow.com), and a DIY from eHow:
http://www.ehow.com/way_5513540_hond...r-removal.html
Have fun taking it apart, keep us updated
Old Apr 18, 2011
lazlong's Avatar
Spray some lube in there and wiggle it.
edit: Ok, that sounded really horrible. lol. I meant lock lube.
Old Apr 18, 2011
Zeferint's Avatar
Autocross Padawan
If he can't get it back to the "off" position the key, lodged or not, wouldn't be able to come out.
Old Apr 19, 2011
lazlong's Avatar
With lube you may be able to get it to turn back to OFF if the cylinder is worn enough. It sounds like it may be worn enough considering it turned to ON. Otherwise it's dis-assembly.
Old Apr 19, 2011
stevennaka's Avatar
stevennaka is an unknown quantity at this point
1. use a phillips screwdriver to remove the lower ignition cover. 3 screws
2. remove lower ignition cover.
3. use a security torx 30, to remove screw on bottom of ignition,
4. use a pic or a small screwdriver to push in pin on top of ignition switch.
5. remove ignition switch (switch needs to be in position 1)
Old Apr 19, 2011
stevennaka's Avatar
civic_gt
Apr 19, 2015 08:15 AM
Killagi
Apr 12, 2015 10:42 AM
Hrddrvs
Apr 11, 2015 11:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Lightman
Nov 10, 2001 06:44 PM
