aftermarket temp gauge questions
hello guys and girl. i have a b16a2 in my 1990 honda civc hatchback.
i bought a aftermarket water temp gauge but not sure where to put it in the block. i could use some help.
Thanks
Thanks
Re: aftermarket temp gauge questions
some kits have an adapter that screws into the engine block coolant drain bolt hole. it replaces the stock bolt that just acts as a plug.
they have oil temp adapter plates that install as a sandwich with the oil filter, but im not sure about pressure. the coolant drain bolt is close to the oil filter if you look around up there when doing an oil change.
some have the sandwiches with more openings for dumb oil switch, pressure and temp guages. I found mine looking for the greddy one. just goggle.
Xuhme
21
Aug 7, 2023 03:40 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
petesdodgyhonda
Jun 19, 2015 09:04 PM
brian257
Jun 4, 2015 08:17 PM
zaboomafoozarg
May 30, 2015 09:21 AM
1990, 35, 91, aftermarket, alternative, civic, coolant, gauge, honda, install, oil, switch, temp, temperature, working
