97 Honda Civic HX -Check engine light (need advice on 4 Codes)
Old Mar 23, 2011
fernando97honda's Avatar
fernando97honda is an unknown quantity at this point
I have a 97 Honda Civic HX with the check engine light on. I need to clear it by this friday for a smog check. The codes I got are P0303, P0304, P1300, P1399. Occasionaly when driving the check engine light blinks but clears back to a sold light when I release and press the gas pedal. The car drives perfectly with the check engine light on and the occasional check engine light blinking. The car accelorates fine, it basicly run very well but I don't understand why I can't clear the check engine light when I've already changes the spark plug wires, spark plugs and the cap and rotor. Can you help and tell me what I need repair to clear the check engine light?
Thanks in advance,
Fernando Gamboa
Last edited by fernando97honda; Mar 23, 2011 at 04:12 AM. Reason: need daily email notification.
Old Mar 23, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: 97 Honda Civic HX -Check engine light (need advice on 4 Codes)
Thanks in advance,
Fernando Gamboa
reset the codes using a portable obd2 scanner tool if not avail
take out battery for about 5 min
neg terminal
Old Mar 23, 2011
lazlong's Avatar
First, you may not pass on Friday even if you fix it today. You usually need at least 100 miles in all conditions to reset all the readiness codes.
For P1399 Honda has reported clogged EGR passages and valve clearance issues as being the cause(s) of this code.
Take the EGR off and clean it and the engine passages you can reach with carb cleaner. Then reset the ECU thru a scan tool or removing the neg battery cable. Drive it around a little bit then check for codes again. If no OBD codes- drive it a while to set readiness codes and then get it inspected. If it still has OBD codes- check valve clearance.
Old Mar 23, 2011
MelJ's Avatar
Trance Addict
Yeah. I'd try and actually take care of the problem, because like lazlong said, they're still stored in there for a while until the computer runs the checks over and over again to make sure the tests are okay.
Xuhme
21
Aug 7, 2023 03:40 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
