what type of struts should i buy if my 04 lx is lowered?
Old Mar 14, 2011
derek9087's Avatar
derek9087 is an unknown quantity at this point
any help is much appreciated
Old Mar 14, 2011
MindBomber's Avatar
Live for the Twisties
Re: what type of struts should i buy if my 04 lx is lowered?
Tokico hp are probably the best option for you, how much is it lowered?
Old Mar 14, 2011
+1 for tokicos, mine are going over 5yrs on eibach springs and they still good. the tokicos can handle upto 1.5-1.7 inch drop.
Old Mar 14, 2011
SedanB0y1's Avatar
SedanB0y1 is an unknown quantity at this point
gearbox, which eibach springs do u have? prokit of sportline? and what are ur wheel dimensions? im going with sportline with kyb, just want to get a feel on how you like the look of the drop and the ride. thanks!
Old Mar 14, 2011
MindBomber's Avatar
^KYB GR-2 are junk and lowering springs will blow them out, if your planning on going that route.
Old Mar 14, 2011
SedanB0y1's Avatar
Gah! i dont kno which shocks to go after!
so which have do u know is best with sportlines?
Old Mar 14, 2011
MindBomber's Avatar
The best?
Bilstein, Koni Yellow inserts or tokico d-specs.
The ones that will suit your needs and budget best?
Tokico hp, no competition, they are the hands down best.
Old Mar 14, 2011
i have prokit and tokicos with stock rims and tires with roughly 2 finger gap (like 1.5 inch) between fender and wheel. ride is stiffer than stock, but tolerable. i would never go lower and even now i still tend to scrape up my aftermarket exhaust. im going back to stock tho when i can afford it cause this pipe sits way too low. other than that i only scraped my front bumper with lip kit one time on a steep driveway. when these tokicos go bad, which they dont seem like it anytime soon, i will throw on a new set. i could never go back to oem, its way too bouncy and makes me sick when the car keeps moving up and down over every little bump. ive taken these tokicos over some very rough roads, big potholes, even dirt and rocks with the car shaking like crazy and completely loaded with 500+lbs of stuff in the car for 2k miles and never had any issues. they are still at the same height when installed and when you do the bounce test by pushing down hard on the rear, it bounces right back up the first time and stops.
actually i just looked thru some old records and my tokicos are only 4 yrs old. still darn good for a lowered car that i expected would only last couple yrs.
Old Mar 14, 2011
MindBomber's Avatar
Spring wise, I use H&R because unlike other lowering springs they drop the car so it sits level. If you have your heart set on eibachs, then you need to decide whats more important to you.
Using prokit springs you are at the ideal height for handling and a good functional height, speed bumps won't be your arch nemesis, and the spring rate is fairly low so the ride will still be comfortable.
With sportline springs you drop lower, you won't like speed bumps with these and if you have a front lip it will become your personal mission to rid the earth of them. The spring rate is much higher on sportlines, so the ride will be harsher but if performance is your main concern these are the option you want.
Old Mar 14, 2011
civcowner99lx's Avatar
civcowner99lx can only hope to improve
im stupid for doing this but bordem got to me i wanted to put in new gauges in my 99 civic lx and i removed the needles but put them back on the stock ones nothing works no speedometer or odeometer please help!!
Old Mar 14, 2011
SedanB0y1's Avatar
my case, daily commuter to school and back. want a great look with nice ride. if i were to go with eibach i would def do sportlines (since i want a nice drop hehe ). I have no lip kit and dont plan to get one ever. since u have mentioned bilsteins, i will go with those bc my buddy (who will do the work for me, is a mechanic) recommends doing kyb or bilsteins, he doesnt like tokico. but obviously i am seeing the opposite on our forum.
funny you mentioned H&R bc an acquaintance recommended H&R with spec-D! so im seeing H&R / Sportlines are comparable and dont matter which you go with, so its just a matter of shocks at this point. would go with eibach bc have years of great rep. Budget is 600.
Thanks alot for both of you for your help! this is really helpful in making my decision! (sorry for the long book lol)
Old Mar 14, 2011
MindBomber's Avatar
Start a thread and you'll get some help.
Old Mar 14, 2011
MindBomber's Avatar
I'm a suspension *****, I have spent countless wasted hours reading about different set-ups and talking to people at meets and I have never heard of someone using tokcio hps on a proper set-up being unhappy. The only person not happy with tokico hp are people who slam 2+ inches and blow them out.
If your budget is $600 you can afford tokico hp and lowering springs. KYB AGX are roughly $550, Bilstein are $1000, and D-spec $800 i think without lowering springs.
Old Mar 14, 2011
if you can afford it, ofcourse bilstein is the way to go. with sportline, it will be a nice setup.
Old Mar 14, 2011
SedanB0y1's Avatar
woah bilsteins are that expensive!! well in that case, it looks like i will have to go with the tokico hps! thanks alot guys!! great help in deciding for final, now i can sleep really appreciate the help!
Old Mar 15, 2011
SpeedDownZone's Avatar
question thinking of lowering as well and seems to me everyone i know just cuts the spring or burns them or something like that but there car feel like your riding in dirty road even if its a smooth road. will this be everything i would need taking in account the advice given in this thread.
http://www.autopartswarehouse.com/sk...n+%26+Steering
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Old Mar 16, 2011
thefatalepic's Avatar
thefatalepic is an unknown quantity at this point
I'm looking into the same set-up for my Civic. But, (and I'm hoping someone jumps in on this) I'm not sure if the 1.4" drop is too low for 18" wheels with 225/40/18. I might go with the Pro-Kit since it's only 1" drop but I dunno.
BTW, I would use THMotorsports.com, they have the Tokico HP and the Eibach springs for cheaper. I ordered the rear Tokico and they were delivered in a little less than a week. You'll save money - everything is less expensive there and the shipping is still free.
Old Mar 16, 2011
thanx i was not really going to buy from there just put that up to see if its everything needed for a drop done right. yea and help will come sooner or later.
actually they seem to be priced almost the same with thmotorsports.com being about 10 bucks more in those cases i usually buy it from were ever its closer to me.
Old Mar 16, 2011
look for Max's posts - they have some info.
https://www.civicforums.com/forums/4...-they-fit.html
This is for a 6th gen, but Max posted some more info there as well.
https://www.civicforums.com/forums/1...s-too-big.html
Old Mar 17, 2011
Definitely do what's best for you. I just wanted to mention on my end when I look up the same parts on THMotorsports everything is about $10 cheaper - I'm not sure what's going on there.
@sdaidoji, I can't thank you enough. I've actually decided to go with the 1" drop (Eibach Pro-Kit) for now. I figure it gives me a bit more leeway - I'm a heavy guy and the I-10 is a vicious ***** of a freeway. If I decide to go with 17" wheels in the future - I'll go for the 1.4" Eibach Sportline. 17" sounds so much better in terms of function - but I can't help it I like the way the 18"s look :P
Old Mar 17, 2011
thank max for his good info
Old Mar 17, 2011
Done and done.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
beachglass
May 22, 2015 09:59 PM
bo_red
May 4, 2015 01:47 PM
bsmiley
Apr 27, 2015 01:27 PM
