8th Gen 2006 - 2011.
Finally my Civic is here, lot of question
Old Mar 4, 2011
GTR-Mclaren's Avatar
GTR-Mclaren is an unknown quantity at this point
Hi, Im new in the forum
great forum BTW
this is my baby:
Civic 07 coupe, auto, the basic one
imported form USA to my country, El Salvador
just 6000$ total !!!!!
anyway, its feels good...but the miles are a little high 99k
so....I have some questions...first, mechanical question:
-my car "jumps" a little sometimes when it change from 1st to 2nd gear...its like it getting out of gas, even with the tank full
this problem is not constant, it happen sometimes
-The exhaust have like litthe "rocks" inside...I dont know how to call it, but when it moves I can hear like small rocks "dancing" inside...how can I disarm it to clean it ??
-Im getting like 24mpg......its supposed that the car should give almost 30mpg...so...I dont know whats wrong
now electrical:
-Radio is dead.....well it have a code...but I dont know it...what can I do ??
thats all...please help, I really like the car but I want to solve that problems
Old Mar 4, 2011
MelJ's Avatar
Trance Addict
Re: Finally my Civic is here, lot of question
Nice avatar, MGS is one of my favorite game series of all time . When you say jump, do you mean the car kicks you back into your seat? I haven't driven an automatic in quite some time, but it might just be the way you apply the throttle. The further you push it down, the later and harsher it will shift. As for the MPG, I'm assuming El Salvador is pretty warm year round, so you probably don't have "winter blend" gas. It could be your driving habits. Are you doing a lot of city driving? That is a killer on mpg(ie stop and go). It might need a tune up. It's hard to say.
Old Mar 4, 2011
MindBomber's Avatar
Live for the Twisties
It's definitely possible that you may just have a bit of a lead foot at the moment, I know I do when I get a new car. Otherwise, the car may be in need of a tune-up after five years.
The "small rocks" are probably the exhaust bouncing around a bit on the hangers, check that all the bolts are tight.
Old Mar 5, 2011
thanks for the answers
I have solved the radio problem
but Im still worried about the mpg
Im doing a lot of city driving and the temp here is 30c
maybe that why
Old Mar 5, 2011
MindBomber's Avatar
Is the tire pressure correct?
I would definitely consider changing the air filter, then cleaning out the intake and throttle body. If those are dirty you would have a fairly significant drop in mpg.
Old Mar 24, 2011
uumm what the ideal tire pressure ?? 28 ?? 30 ??
Old Mar 24, 2011
MelJ's Avatar
Trance Addict
check your door jamb(the area where the door closes). There should be a sticker there with your VIN and some other things. One of those being tire pressure ratings. This pressure is for COLD tires, as they will heat up and pressure will increase once you've driven about a mile or so.
Old Aug 22, 2011
Hello again, I have another doubt about my Civic
Yesterday the "B Oil life 15%" message appear
Today I change the Oil motor and the transmission Oil with the exact oils for my car
but the message is always there !!! its something wrong or it will go away with time ??
thanks
Old Aug 22, 2011
i think you have to reset the timer or whatever it is.
Old Aug 22, 2011
sl33pyriceboi's Avatar
run it between 30-35.
i run it around 32 all round.
also check ur engine air filter.
are u using the AC (air conditioning)???
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
dano2005
Apr 14, 2015 01:58 AM
GoofyLogicInc
Oct 22, 2001 03:04 PM
Handsonme
Sep 4, 2001 06:31 PM
