no fn spark....lol
no fn spark....lol
ok so ive figured out alot of my dpfi to mpfi probs through process of elimination
but as of now i am getting no spark, I was a week ago when i had it running on the mpfi setup, it just ran like crap lol.
its throwing 0 codes
the dizzy is BRAND NEW, so that writes out the icm and coil
the plugs are in good shape as well as the wires rotor and button are ok
i have all of my wires pinned correctly (had a friend double check)
my ecu is good it comes on throws a blink at startup, dtc light goes on and off
main relay clicks at aux position
cam spins and timing belt is good
timing is set correctly
checked fuses
im simply getting no spark
to be honest i dont believe im getting sufficient power from the ecu to the dizzy, but i wanted to see if ive overlooked anything else
checked fuses
Re: no fn spark....lol
get this i got 12v goin to all power wires, dizzy is brand new. the coil though....and this is the funny part lol when tested has 0v when tested the ground reads as a positive as well as the initial positive itself it reversed polarity on me lol.
