Need help with my car.
Okay Problem with my car is that the timing belt keeps moving off the cam but it dosent come off and I have the belt on pretty tight but not too tight. Also when I start my car it well make a loud noise for a few seconds and it will go away and it will make the same sound while I'm driving. I would also like to add I just replaced the timing belt and the water pump. Any thoughts or ideas will be appreciated. BTW It's A 1.6 block with a Z6 Head,104 tooth timing belt.
Re: Need help with my car.
If the timing belt moves off the cam then you have 1 of 2 problems, incorrect tension or pulley alignment. Secondly you are going to have to be more specific about the sound, is it like a belt squealing, metallic grind, etc.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
JLee93
Aug 21, 2015 05:44 PM
alaga
25
Aug 13, 2015 04:42 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
