Question about rear door window moulding.
Old Jan 14, 2011
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
I bought a new driver side rear window moulding to replace the old one that was leaving brown goo on the window. What is the best way to remove the old moulding?
Old Jan 14, 2011
lazlong's Avatar
Re: Question about rear door window moulding.
If it's the vertical piece pull back the door seal and look for a screw(s) that hold the trim on, start at the top as there may only be one. Once you have the screw(s) out, pull up/out on the trim piece.
If it's the horizontal piece then pry it off with a trim tool. Harbor Freight has a cheap set. Get the metal ones, not the plastic set. Be sure to put something soft like a rag between the tool and the paint.
Old Jan 15, 2011
Bugman1400's Avatar
It's the horizontal piece. I'll stop by Harbor Freight today........Mucho Thanks!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
S.Klinck
Jun 11, 2015 10:27 PM
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
