2002 civic / hydraulic clutch / 5-sp / problem either with clutch or with starter ?
Old Jan 8, 2011
pnamajck's Avatar
pnamajck is an unknown quantity at this point
2002 civic lx / hydraulic clutch / 5-sp / problem either with clutch or with starter ?
engine has 260k highway miles . . . clutch / starter original.
while car is running, i can access all the gears without difficulty . . . just starting the engine is the problem. seems each week i have to press the clutch pedal further down . . . today all the way down to the floor . . . before starter finally initiates.
realizing a driver needs to push down the clutch, in order to start the car (safety issue) . . . does this switch need replacing . . . or is the hydraulic clutch really going bad ?
oh yeah, one other thing . . . there seems to be a couple drops of oil / fluid on my garage floor that are quite recent.
based on the info i gave, if it is the clutch going bad . . . would it be the hyd-master or hyd-slave cylinder . . . or some other focus entirely ?
thanks in advance for your knowledge / experience.
Old Jan 8, 2011
MelJ's Avatar
Trance Addict
Re: 2002 civic / hydraulic clutch / 5-sp / problem either with clutch or with starter
Usually, if one of the cylinders goes bad, it's usually the slave IIRC. My car, and every other standard I've driven, behaves the same way when starting. The clutch needs to be floored in order to start it. I mean, it seems like that. I've never really thought about it since I always did that when learning. Check to see where the fluid is coming from if you can. Check the reservoir as well. A guy on another forum I frequent had his CSC go and fluid got on his pedal and on his foot. I work on my car so I know the smells of all the fluids. I can't really describe them, so I don't know how to help you with that.
Old Jan 8, 2011
pnamajck's Avatar
slave cylinder . . . ic . . . thanks for your quick input.
Old Jan 8, 2011
MelJ's Avatar
Trance Addict
I would wait around and see what the other members say, just to be safe though.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
shaejb15
Apr 26, 2015 07:44 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
