*rumbling* on front passenger wheel
Old Dec 17, 2010
Kobo the hobo's Avatar
Kobo the hobo is an unknown quantity at this point
While I'm driving my 01 civic, the front passenger wheel will make a rumbling noise and i can feel it in the steering wheel. It happens on occasion and the length of rumbling differs, no longer then 3 seconds. most of the time it's only like 3 quick rumbles (I can tell) but has been lasting longer lately. I doubt it's the brakes, had my car at Les Schwab like 2 weeks ago to check up on the brakes and they said it's fine.
I've jacked the car up and looked at the wheel and it doesn't wiggle.
Any ideas on what might be going on?
Also, I had my timing belt, fan belt, and fuses replaced about 2 months ago and my fan belt is screeching. Tried tightening it but that didn't do anything, should I replace it?
Old Dec 17, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: *rumbling* on front passenger wheel
Fan belt? If you think there's a fan belt in a car made anytime after 2000 you shouldn't be tightening belts at all. Maybe you should tighten your power steering and a/c belts and see if that helps.
Edit://You know what that was mean... Just try replaceing the belts, they're really cheap, make sure you tighten them properly and you'll be fine. Before that try some belt dressing, they may just need some silicone in the cold weather. Check each pulleys ridges for damage while you have the belts off its possible they use a chain wrench on the crankshaft pulley to hold it while they wrenched it off to change the T belt.
Old Dec 17, 2010
Kennykid2002's Avatar
Kenny the Ricer
Balance might be off, or lugnut might be loose
I would take off the wheel entirely, then put it back on, remember to do tighten it star pattern.
See if the problem persists, if it does, its most likely balance
Old Dec 17, 2010
Mad Dog Tannen's Avatar
Does it have stick on wheel weights? They could have knocked some off while doing the brake job!
Does it happen while cruising, accelerating or braking?
Old Dec 17, 2010
Happy Jack's Avatar
Happy Jack is an unknown quantity at this point
I say it sounds like a wheel bearing.
Old Dec 17, 2010
retighten lug nuts, they do get loose over time. i think its 80-90 ft/lbs.
Old Dec 17, 2010
lazlong's Avatar
Bingo! Like the earlier post, first try taking the wheel off and put it back on. Torque: 80 ft-lbs
Make sure there is 1/8 inch deflection on the belts. Deflection: how far the belt moves up and down while running.
Old Dec 17, 2010
MindBomber's Avatar
Live for the Twisties
Adding to what everyone else has said, when you re-tighten the lug nuts if you don't have a torque wrench or impact wrench then you will probably need to use a cheater pipe to get enough torque on the nuts.
When you had your brakes done did they touch the rotors, a warped rotor would cause vibrations as well.
Old Dec 17, 2010
Well they did a brake job last spring, and messed up terribly, the brakes were locking up so over the summer they re-did the whole thing. Rotors were warped but they replaced them. I'll try taking the wheel off and putting it back on.
And it happens while cruising.
So my car doesn't have a fan belt? Well it only screeches when the AC or defroster are on if that helps. (apologies for asking about this on the tires and wheels thread.)
Old Dec 17, 2010
well correction, it's the a/c belt, thanks Prodresurgence. I did tighten it up though.
Old Dec 17, 2010
MindBomber's Avatar
Don't worry about it, its all part of the same series of problems. If it goes to far towards off topic, we simply move it to the appropriate area.
Old Dec 17, 2010
If it makes the sound louder when going around a corner then it is the wheel bearing for sure. It usually happens when turning one way.
I am almost sure it is the wheel bearing!
Old Dec 17, 2010
do you mean like during an actual turn? It's never rumbled while turning, it's usually when i'm cruising and the car is slightly moving to the left. but on the straight aways
Old Dec 17, 2010
lazlong's Avatar
Still think it's the wheel bearing.
Old Dec 17, 2010
Kenny the Ricer
Like I said, remove the wheel and reinstall it first
Old Dec 17, 2010
It usually happens that way but not always. Sense it's a grinding sound, then it's probably the bearing.
Also check and make sure the CV boots aren't torn while you have the wheel off!
Old Dec 18, 2010
all right. I'll try fixing it tomorrow.
Old Dec 22, 2010
Turns out it's not the bearings, most likely the upper CV joints.
Old Dec 22, 2010
lazlong's Avatar
Upper? It's either inner or outer.
Old Dec 22, 2010
the_civy's Avatar
the_civy is an unknown quantity at this point
sounds like your tire is separated.
shaking in the steering wheel and veering to the opposite side (ex: your passenger tire is the problem and youre pulling to the driver side) are usually signs of a separated tire.
Feel around the tire for a "bubble" or take it to a tire shop and they can check.
Old Dec 23, 2010
04 Honda Civic's Avatar
Sounds like a wheel bearing or axel hard to tell, our cars dont have fan belts. They are electronic.
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
superstanko
Apr 28, 2015 04:38 AM
ImmortalEX
Oct 31, 2001 10:00 PM
