8th Gen 2006 - 2011.
radiator upper hose
Old Dec 16, 2010
liuxinbing's Avatar
liuxinbing is an unknown quantity at this point
radiator upper hose
My coolant is leaking at the spot where the upper hose meets the radiator. I have to add half litre of coolant every week. The upper hose connector is the only place leaking.
Do I have to remove the bulkhead cover to gain access to the connector? Do I have to change the hose or just wipe out debris on and around the connector and re-insert the hose?
The clamp is rusted and can't be reused. Can I use an universal stainless steel hose clamp shown in the picture?
I bought my 06 Civic coupe then found this problem. Thanks to everyone for looking.
Name:	hose clamp SS.jpg
Old Dec 16, 2010
lazlong's Avatar
Re: radiator upper hose
You shouldn't have to move anything to get to the clamp. If the hose is undamaged then clean and re-use it. Universal clamps will work fine, I have several on my car. You can almost buy a whole package for the price of one clamp from Honda.
Old Dec 16, 2010
liuxinbing's Avatar
Thanks.
I had no access to the clamp because it's under a steel protecting plate. To remove it, I had to first remove the plastic cover by prying the clips (C). Unfortunately I broke the plastic clips(C) when prying.
Is there any special skills to safely pry out the plastic clips?
Old Dec 16, 2010
Mad Dog Tannen's Avatar
I would cut off the old squashed part of the hose and reuse the rest. Those clamps will work fine.
Old Dec 16, 2010
lazlong's Avatar
Pry up on the middle part with a flathead. You'll end up breaking some. When I'm gonna be taking those body pins out I go buy a box or two at the auto parts store.
Old Dec 16, 2010
liuxinbing's Avatar
good point! I will buy a dozen clips from CarQuest.
USCGBM
Aug 12, 2015 04:22 PM
mrwhos
Aug 11, 2015 02:03 AM
Tdmnds
Aug 5, 2015 04:23 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
silentz
Jul 9, 2015 08:16 PM
