1991 crx si jdm b16a $2200 0b0
im selling my 91 crx to pay for college
jdm b16a swap with receipts (obd1)
ENGINE MODS:
golden eagle pro series fuel rail
walbro 255 fuel pump
earls braided steel fuel lines
summit racing billet fuel filter
blox fuel pressure regulator
HAD throttle body
short ram intake
full exhaust with headers there is an exhaust leak but i could get a wrapped dc 4 to 1 header for cheap if you are willing to pay for it about $100
wire tuck
jdm p30 ecu
new o2 sensor ( will include a full wide band o2 setup that i pulled off after the old motor blew.)
new knock sensor
y1 trans with lsd
stage 2 clutch
new axles and new half shaft
MOTOR HAS A SMALL ISSUE. I BELIEVE IT NEEDS A NEW COIL OTHERWISE ITS FINE. ESTIMATED 32K ON THE MOTOR TOTAL
ALL OTHER MODS:
lowered with H&R springs and kyb adjustable shock
new rear brakes dimpled and slotted rotors new pads and new driver side caliper
battery located in trunk (the battery is less than a month old)
the car is dynamatted
some interior parts could stand to be replaced but i have everything.
Personal grinta steering wheel with nrg quick release ball bearing style
pioneer head unit and speakers
carbon fiber sun roof (works great)
the car also needs tires and ball joints but nothing major the ac was stolen at a shop and the heater core needs to be replaced, but this would make a great track car its fast responsive and handles like a dream car has been babied since the swap never ran past 7800 rpm (8500 rpm redline)
I WOULD LIKE TO GET $2200 BUT WILL TAKE NO LESS THEN $2000 SO DONT BOTHER LOW BALLING. NO TRADES. FIRST COME FIRST SERVED. OVER $5000 DROPPED ONTO THE CAR IN THE PAST 3 MONTHS. GREAT PROJECT CAR OR DAILY DRIVER. I HAVE THE CLEAN TITLE IN HAND AND READY TO SIGN! car is in hurricane utah pick up only will need to be towed unless you bring tires. i will tow it 100 miles for you ( may have new tires this week i will update the add when i find out)
dont pm i dont get on here much
call, text, or email
(909) 549-8217
bondt5@unlv.nevada.edu
The sooner i sell it the better spring semester starts in early january. Thanks for looking.
ENGINE MODS:
HAD throttle body
short ram intake
wire tuck
jdm p30 ecu
new knock sensor
y1 trans with lsd
stage 2 clutch
ALL OTHER MODS:
(909) 549-8217
Re: 1991 crx si jdm b16a $2200 0b0
i am willing to part it out 1100 for the motor will include fuel lines wire harness and ecu 750 for trans (lsd) or 1700 for motor and trans. rolling chassis 1500 99% rust free
Zygrene
Mar 22, 2016 12:36 PM
Islesfan
Sep 29, 2015 03:42 AM
