flywheel or intake/exhaust?
Old Dec 11, 2010
autocrosser09's Avatar
autocrosser09 is an unknown quantity at this point
so my transmission is finaly going out and i have a replacement ready to go in. I was thinking of installing a light weight flywheel, like the ACT streetlight flywheel (11.9lbs), but those run about $150-$200, or can anyone suggest a more budget minded quality flywheel for a daily driver?
My question is... would it be worth the money to upgrade the flywheel while i am in there anways? or would it be better if i just resurfaced my stock flywheel and used the extra money for intake and exhaust?
I already have a muffler installed and a header will be put in when i replace my bad tranny.
My car is a 2000 EX and it is my daily driver. I do not plan on boosting.
And yes i did do my research so please do not tell me to use the search tab.
Old Dec 12, 2010
bluhonda's Avatar
bluhonda is an unknown quantity at this point
Re: flywheel or intake/exhaust?
Ok I hear what your sayin. I you a runnig a single try to find a 88 to 91 crx si fly wheel they weight 8 pounds thats the litest one. If you are running duely, try to find the litest fly wheel you can from any 91 to 2000 b16 or b18. It will bolt up to your motor I've done this meny times and still runnig mine. Happy hunting
Old Dec 12, 2010
MindBomber's Avatar
Live for the Twisties
I would upgrade the flywheel, decreasing the rotational mass straight off the enginel is extremely beneficial.
Old Dec 12, 2010
BlueEM2's Avatar
Whachya lookin at?
Flywheel man, you can always get at the intake/exhaust, but the flywheel is a lot more work. Get it while your there!
Old Dec 12, 2010
Great. Thank you all for your input.
"Bluhonda". could you elaborate a little more about what you were saying about single or double. I'm not following you. I was looking into the ACT 11.9 lbs streetlite flywheel. I have done a lot or reading on this subject through different forums and found that the smaller weight flywheel the faster your RPM's will drop between shifting. So I would like to stay about in the middle between heavy (16 or 18lbs) and light (7.5lbs).
That was just what i came up with. if you can suggest something better then by all means let me know..
One more thing... I didn't think that the B series would fit on a D series... is that correct?
Old Dec 13, 2010
BlueEM2's Avatar
Whachya lookin at?
No stick with the "D" series. Make sure it's engine specific. It might fit, but.. it probably wont.
Old Dec 13, 2010
bluhonda's Avatar
You never said in your post if you have single cam or dual cam setup in your car. I know a few people that race there cars in the civic and integra classes. They run stock or mod and use lighter fly wheels for a faster acceleration, and found that it wont take away from there rpm band. Me personaly im running a atc streetlight fly wheel with my B16. The street class your looking at, if thats the one go for it.
Old Dec 13, 2010
Its single cam. I have the EX... wish it was dual. ok great. It looks like i will most likely get myself a flywheel then...
another question: like i said this is my daily driver (though i do autocross two or three times a year). I still want my comfort. Would it be best to stick with my stock clutch? or should i upgrade to something more performance oriented? like i said. i'd rather not sacrifice too much comfort.
Thanks agian for you help everybody!
Old Dec 13, 2010
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
i have fidanza flywheel and they are 7lbs
with exedy oem clutch
this is my second time around changing and using the same product
i love it ever since
OptimisticWay
46
Oct 15, 2015 02:16 PM
beanhead
Sep 24, 2015 12:04 PM
naokigoffi
Aug 30, 2015 06:19 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Vaguexo
Jun 13, 2015 04:11 AM
