1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Car wont start (sometimes)
Old Dec 9, 2010
dainfamouswun's Avatar
dainfamouswun is an unknown quantity at this point
I have a 94 civic(4dr) and for the past month or so its been giving me some starting problems. it wont start(sometimes) after its been parked for a couple hours or over night. some days i start it in one turn, and some days i have to turn the key atleast 2-3 times before it starts, and some days it just wont start at all. so i figured since its getting to winter, maybe its the bettery. so i bought a new battery( coming up on 3 weeks since i got the new battery). for the first 2 or 3 days it seemed to be fine, but now its doing the same thing all over again. i dont think its the starter, mayb the altenator?..if its the altenator, how do i go by replacing it?...can i do it from the front or do i need to go from underneath?..
thanks for the feedback(in advance)
Old Dec 9, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Car wont start (sometimes)
If you're getting it to start, might not be starter.
Cold temperatures will affect battery performance, and if it isnt getting fully charged every day, then CCA of the battery will drop
Would be a good idea to get alternator checked out at a auto parts store though
Old Dec 10, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
could be the ignition switch. The was a recall on civics around this time and its still available. Mine started to go a few months ago and i took it into my local dealer and they fixed it right away for free. Does the car ever just stop running when your driving it?
Old Dec 10, 2010
djsunshinee's Avatar
djsunshinee is an unknown quantity at this point
I have a 2010 honda civic got it recently..and i did not use it for one month or so..when i tried to start the car it does not start..I would like to know is the new car has a major problem or is it just the battery?
Old Dec 10, 2010
MindBomber's Avatar
Live for the Twisties
Probably the battery, never leave a car for a month or so without starting it, it is extremely hard on the engine. In the future either start it and go for a short drive once a week yourself if your unable to do that have someone else do it for you.
OP: test the alternator, you can do it with a voltmeter or an auto-parts store might do it free of charge.
Old Dec 10, 2010
Kenny the Ricer
8th gen civics have a common ignition problem, turn your key to "ON" position, leave it there for about a good 10~20 seconds, and then crank it.
Old Dec 11, 2010
BlueEM2's Avatar
Whachya lookin at?
Moved this thread over to 1-5th gen civics. More appropriate here and you might get more help.
Old Dec 11, 2010
89civichatch's Avatar
89civichatch is an unknown quantity at this point
i have a 95 accord and i had this same problem,took it to a honda specialist and it was the main computer,only costed me 150 for diagnosing it,parts and labor,i would check that out after texting the alternator.good luck
Old Mar 2, 2011
yingcivic's Avatar
yingcivic is an unknown quantity at this point
i have a 94 civic ex vtec 5-speed and its been having trouble starting it the battery is brand new, just replaced the starter today and it still wont start, any suggestions?
Old Mar 12, 2011
wehrd1's Avatar
wehrd1 is an unknown quantity at this point
if it's been sitting in the sun and it's very hot inside, and won't start, it's because of bad solders on the main relay control unit under the steering wheel. when it gets very hot in the interior, the solders on the board lose contact.
open all the doors, and let it cool off inside, if it starts then, thats your problem.
go to any electronics store and get some cold spray and squirt it, to verify thats your problem the next time it won't start.
...or always park in a shaded area, with your windows down.
i had this problem on 2 of my 3 92-95 civics, and got replacement (rebuilt) main relays with the solder already redone for like $12. hasnt happened since replacement.
Old Mar 22, 2011
marshal12's Avatar
marshal12 is an unknown quantity at this point
Hello.
I think your car's battery connector is not properly. You should take it new. 2 days ago I also faced this type of problem. I buy new connector from here. And now It is working good.
thanks!!
Old Mar 22, 2011
ebanuelos's Avatar
ebanuelos is an unknown quantity at this point
Angry Re: Car wont start (sometimes)
i am having the same problem except mine is automatic. I have already replaced relay, and ignition switch. My fuel pump doesnt prime, and my injectors do not open.
Old Mar 23, 2011
ebanuelos's Avatar
Originally Posted by marshal12
Hello.
thanks!!
but i have light in the car and errthing?...
Old Mar 27, 2011
DRAM2500's Avatar
DRAM2500 is an unknown quantity at this point
THESE CARS ARE VERY BAD FOR COOKING DISTRIBUTORS, I had the same problem and took m,e a while to figure out. Take a good look at yours, mine was fried inside, some wires were burnt a bit.
Old Mar 29, 2011
ebanuelos's Avatar
but wouldnt my battery die out if that was the case.. i have had power for a while, its just starting is the difficulty
Old Jun 11, 2011
rahimB's Avatar
rahimB is an unknown quantity at this point
Megan Racing coilovers
Hello,
Easy suspension tuning is in your hands. S - Tech was made so that everyone can enjoy sports driving. TEIN based these springs on original specification so that the installation is easy. Full compliance with car inspection, and great styling. Adding some more exicitement to your ride.. The highest quality brought to you at great JayDM prices. Now comes in two types to choose from.
Old Jan 31, 2012
NamedMyDogCivic's Avatar
Turboed Hatch
NamedMyDogCivic is an unknown quantity at this point
I JUST HAD THE SAME PROBLEM AND I HAD A MECHANIC LOOK AT IT FOR ME AND IT WAS MY GROUNDS I HAD TO TAKE OFF THE MAIN TRANNY GROUND AND THE NEGATIVE GROUND POST AND SANDED THEM BOTH DOWN AND IT STARTED RIGHT UP. I WAS SUPRISED TO BECAUSE I NEVER WOULDVE TOUGHT IT WOULD BE THAT. if that dont work go to autozone and theyll test ur starter for free. good luck man
Old Feb 10, 2013
Kwozney's Avatar
Kwozney is an unknown quantity at this point
I'm having a similar problem. I have a a 92 civic cx and it starts fine, but i was learning how to start on a hill & stalled and it wouldn't start, I tried jumping it and it wouldn't turn over. It's as if it had no power. I got it to a flat area and let it sit, & after a few attempts it started and ran like nothing happened. I thought since I just bought it that it might have sat for a while before hand and water maybe got in the fuel pump and was causing this, I replaced it but its still doing this, but only if I stall on a hill. I am thinking maybe the alternator?? Any one know what it might be?
Old Feb 7, 2016
debord58's Avatar
debord58 is an unknown quantity at this point
I have a 2012 Civic and if I let it sit a few days now that it is cold outside it won't start. Just bought a new battery. So pretty much the same problem.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
