1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
2 hoses on left side of motor???
Old Nov 23, 2010
95civicSauls's Avatar
95civicSauls is an unknown quantity at this point
I have a 95 civic i was cleaning somethings under the hood today and i notice that there was 2 hoses not connected to nothing the one hose came from the car almost to the motor and the other one comes from the motor right below the throttle i dont know if they connect to each other but they both have metal peices at the end kinda looks like bolts could anyone give me any ideas what it might be to
Old Nov 23, 2010
Re: 2 hoses on left side of motor???
the one hose connects by the fuel injecters on the left side but not connected to anything else
Old Nov 23, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
take a picture.
Old Nov 23, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Sounds like a FITV bypass. The hoses were blocked off with bolts to keep them from leaking. Pics would help determine for sure.
Old Nov 23, 2010
Will get Pictures soon is it bad to be driving with it broke i dont know how long they been broke and does any one know how much this prt cost?
Old Nov 23, 2010
Kennykid2002's Avatar
Kenny the Ricer
If it's a bypass, its not broken.
Take pictures
That's the only way to diagnose
Old Nov 26, 2010
i couldnt figure out how to put the pics on here but there on my profile if anyone can help thanks
Old Nov 26, 2010
Kenny the Ricer
Old Nov 27, 2010
are they sopose to connect? what is the hose called?
Old Nov 27, 2010
TiggerDX's Avatar
Really hard to tell from those pics. Can't really even tell what part of the engine they are at. I am almost thinking it's your heater core being blocked. Almost looks like the return line. Any chance you have a real camera to snap the pics?
Is the hose coming from the firewall near another one of the same size?
What would you say is the outer diameter of the hose?
Is that a disconnected port under your hand in the second pic? (just to the left of the arrow)
Old Nov 27, 2010
in the first pic its connected to the intake manifold i believe on the left side of the motor the other one is connected to the car i guess the fire wall they are about the same size i dont know why they have bolts in them though i was thinking bout utting a new hose on to connect to both ends but not sure i dont think its been affecting the car. i know my tps is bad but other then that nothing
Old Nov 27, 2010
phil_89's Avatar
phil_89 is an unknown quantity at this point
ur heater work...?????
Old Nov 27, 2010
TiggerDX's Avatar
I'm still guessing the heater core. Not sure why it would be blocked off unless it was leaking.
The bolts are in there to keep the fluid from coming out. Pull out one of the bolts and see if it's coolant in the line.
Check your heater and see if it blows hot air.
Old Nov 28, 2010
naw my heater hasnt worked since i got the car but the fuse is blown for the heater so i thought that was the problem would it be ok to get a new hose and replace it
Old Nov 28, 2010
Zoom out some so we can get some context as to where it really is. Taking a picture of just the hose won't help us locate where it is/what it's supposed to do. Heater core hoses does sound like a possibility.
Old Nov 28, 2010
TiggerDX's Avatar
IF it is the heater core, there are only 2 reasons I can think of that it was cut and plugged. Either the hose leaked and they were too lazy to replace it, or more likely the heater core leaks, which would require replacing it.
You need to make sure what it is first. The pics below are from a 94 DX D15B7.
The hose in the first pic which comes from the intake goes right back to the water outlet below it. Both circled in yellow.
The hose in the second pic goes to the heater core. It looks like yours based on the clip.
So to me, it looks like the hose in your second pic is to the heater core and connects to the intake manifold. Not sure if they rerouted the hoses in 05 or if yours is a 1.6.
ID:	79695   Click image for larger version
Poopies
Apr 20, 2017 11:36 PM
EdGasket
May 25, 2015 01:06 PM
bsmiley
Apr 27, 2015 01:27 PM
popsiclepete
Canada West
Dec 1, 2001 02:04 AM
marlette13
South
Nov 28, 2001 04:08 PM
