8th Gen 2006 - 2011.
Tire pressure light staying on
Old Nov 6, 2010
skobydog's Avatar
skobydog is an unknown quantity at this point
Any ideas as to how to fix?
It's not the TPMS light, it's the light that looks like the cross-cut of a tire.
I've checked all the tires and they have at least 32psi. Somewhere I read to let all of the air out of tires and refill to reset the tire pressure sensors. Anyone find this true?
Would pulling a fuse reset the sensors? Thanks for any responses.
I'm going to rotate the tires this week so any info or suggestions would be helpful.
Old Nov 16, 2010
cinghoa's Avatar
cinghoa is an unknown quantity at this point
Re: Tire pressure light staying on
The sensor is very picky. If I remember right the cheat sheet in the door calls for 34psi all around.
Old Nov 20, 2010
xeryusdvirus's Avatar
xeryusdvirus is an unknown quantity at this point
Did you just buy tires? If so, ask them to try to reset the TPMS sensors.
There are 2 types of TPMS systems:
1) Direct- sensors mounted on the rim. This has to be calibrated or reset with a hand tool depending on the car manufacturer. Others use an automatic re-learn system but you need to drive for a certain amout of distance on highway speed.
2) Indirect- sensors are built in to the car and just need a hand tool to relearn where each sensor id belongs to position of the tire.
Dont bother trying to trick the TPMS. Just get calibrated properly so you dont shorten the tire lifespan.
Old Nov 29, 2010
|-Goku-|'s Avatar
|-Goku-| is an unknown quantity at this point
I had to fill up my tires and drive 30 miles before mine went out. Also, mine comes on every once in a while when it gets really cold
Ma213802
May 18, 2015 07:01 AM
Supramk3
May 11, 2015 07:55 PM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
artychris
Oct 24, 2001 10:14 AM
