New Rotors and Pads! HELP!
Old Sep 22, 2010
kcanoy's Avatar
kcanoy is an unknown quantity at this point
okay.. so i just changed out my rear brake pads and rotors because they were really worn out. but now the new stuff are squealing like crazy!! any input would be nice
Old Sep 22, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: New Rotors and Pads! HELP!
What kind of car is it in the first place?
Are they brand new rotors/pads? BOTH brand new?
Old Sep 22, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Did you put the anti squeal crap on?
Old Sep 23, 2010
lazlong's Avatar
Did you lube the bolts that the caliper slides on? If they look like this buy new pads and lube those bolts with silicon grease.
Old Sep 23, 2010
lazlong's Avatar
User profile.
Old Sep 23, 2010
kcanoy's Avatar
its honda civic 99 ex with 97 rear trailing arms. both rotors and pads are brand new. pads are ceramic ebc's. and rotors are just oem replacements.. is there anything i need to spray on?
Old Sep 23, 2010
lazlong's Avatar
I don't think anti-squeal (goes BEHIND the pad) or anti-seize (goes on the caliper bolts) comes in a spray. Anti-squeal comes in a little packet about the size of a ketchup packet and you usually get ant-seize in a tube. Just ask the guy at the parts counter, he'll know what you need. Take the pads off and if they look like the pic above then throw them away and get new ones and buy both ant-squeal and anti-seize. If they look good just buy anti-squeal. I know anti-seize is silicon grease, can't remember what the other is, sorry.
Old Sep 23, 2010
kcanoy's Avatar
another question. is that thin metal plate thats lightly glued onto the pad itself have any importance?
Old Sep 23, 2010
kcanoy's Avatar
thanks lazlong, i'll look into it
Old Sep 23, 2010
Kenny the Ricer
The clip actually holds the pads in place
Make sure those clips arent touching the rotor,
i know thats the main reason of squeal on my friend's integra
we had to bend the clips back a little
Also, bed your brakes, bed, not bleed
@lazlong
Too much effort :P
Old Sep 23, 2010
lazlong's Avatar
Your car didn't come with rear disk brakes. Someone did a conversion. I'm gonna assume they came from an Integra. Take a look at #13 an #48 in the link and tell me if that's what your talkin about. If it is then yes it's a shim.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Sep 23, 2010
lazlong's Avatar
@lazlong
Too much effort :P
To the OP: nice ride btw
Old Sep 23, 2010
kcanoy's Avatar
ohh not that part. i'm talking about the part thats opposite from the pad thats touching the rotor
Old Sep 23, 2010
Kenny the Ricer
Uhm, i think that's the frame to hold the pad?
Old Sep 24, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
Yes that's like a bracket to give the piston something to press on besides directly pressing on the brake pad. But ally of times when putting new rotors and pads on or even just new pads they will squeak for a day before they are broken in. I wouldn't worry about it unless it's been a few days and it's still doing it
Old Sep 25, 2010
kcanoy's Avatar
thanks steven. glad to know the noise will go away. and i guess i'm stuck on the thin piece of metal because i accidentally threw it away oh well everything still works. thanks for all your input guys
Old Sep 26, 2010
Steven21's Avatar
yeah no problem but you can go to autozone or another car parts store and get the clips and they're cheap too
Old Sep 26, 2010
Mad Dog Tannen's Avatar
@lazlong
Too much effort :P
Are you talking about the chirpers? Chirpers are a little metal piece that comes off of one side of the pads and bends down towards the rotor. Chirpers are there to make noise when your pads need to be replaced (soon). I think your friend needs new pads. Wear indicators in this pic...
Old Sep 26, 2010
kcanoy's Avatar
no. the very thin sheet of metal that the piston of the caliper touches on the break pad. very thin and very malleable. usually has the brand name on it.
Old Sep 26, 2010
I was actually directing that towards kenny, that's why I quoted him.
But just to clarify, you are talking about the shim in the illustration, correct?
SammySC
121
Apr 7, 2017 07:43 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
sf3r8z
Sep 23, 2015 03:26 PM
