1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Noob question, auto tranny fluid 91 DX
Old Sep 22, 2010
barkbuster's Avatar
barkbuster is an unknown quantity at this point
I just picked up a 91 Civic DX, owners manual states dexron II for the automatic trans. I thought I read several posts not to use dexron II or III, but to use the Honda ATF instead. Also while changing the spark plugs I noticed one of the plugs was covered in engine oil, not the threads, just the area covered by the spark plug cap. Any words of wisdom? Thanks.
Old Sep 22, 2010
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: Noob question, auto tranny fluid 91 DX
Use the Honda ATF, most honda manuals say you can use Dexfluid in a pinch for a short time but Honda ATF is highly reccommended. As for the oil on the plug, it's called a spark plug tube seal. They are usually a dollar or less. You will have to pull the valve cover off to change so you might as well change the valve cover gasket too. Here's a link.... http://www.oereplacement.com/advance...Feed%2BTracker
Old Sep 23, 2010
barkbuster's Avatar
Thanks, Honda ATF it is. Since I was going to adjust the valves, I guess I'll find out what the plug seals are all about. Much appreciated.
Burnout
Jul 15, 2022 10:24 PM
MajTom
Jun 2, 2015 11:48 AM
usajags84
May 30, 2015 06:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
viper775
Dec 9, 2001 10:52 PM
