1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Hard start
Old Sep 12, 2010
zrock's Avatar
zrock is an unknown quantity at this point
Hard start
Today my kid changed the plug wires and put teh timming cover back on the 1994 civic. She pulled all the wires off first not paying attention to where they ran. After a quick search we got the firing order right. The thing will barly start and when we get it started it seems to only be running of 3 or 3 cycl. Changed back to the old wires no change. Pulled the plugs and a few had a week spark so going to go get replacements. The car ran fine before she did this and iv checked for loose wires and found nothing. Any sugestions?
Old Sep 12, 2010
Re: Hard start
has to be wrong firing order if it was fine before. try and make sure the wires are properly matched up.
Old Sep 12, 2010
zrock's Avatar
Re: Hard start
i double and tripple checked... got the right firing order. i can pull wire 2 and 3 with no change in the way it runs..after changing the plugs it ran no better. folowed these directions and did some testing to find out coil was bad ( ground was flashing during cranking). now the coil is only 2 months old with less than 500km on it. only reason it was replaced was i lost the spring out of the old one. why would i pop a coil so fast?
http://easyautodiagnostics.com/Ignit...Igniter-4.html
Old Sep 12, 2010
Re: Hard start
is it a honda coil or some aftermarket store brand? same question for the wires. ive seen them come back in 2 months before. many ignition parts you dont want to mess with off brands. except ngk wires are pretty good comparable to oem. and only use ngk or denso plugs. if you dont have a honda coil, i suggest getting one.
Old Sep 12, 2010
zrock's Avatar
Re: Hard start
I have worked in and out of the automotive service for the last 10 years or so and honestly i have never seen any diffrence between aftermarket and OEM parts. In fact i had noticed that over the years the aftermarket parts were actually OEM just had the OEM numbers covered up. Yes quite often with aftermarket especially with reman parts you get a few defective parts but i have also seen the same amount of defective parts with OEM .... just luck of the draw i guess...hehe I will agree on plugs and wires as every veh seems to have their favorite for some strange reason. Yes honda does make a great product but for me to go oem parts in my neck of the woods the stealership has their parts marked up 30 - 50 % more than any other honda dealership... Of course this is just my opinon not trying to **** anyone off here...
On a side note i have never seen a coil fail in this way. It has always eather worked or not... never seen one partialy fail... time to go see what teh warranty is on this part..hehe
Old Sep 12, 2010
02civicsi02's Avatar
Low and slow!
Re: Hard start
Thats what I am saying. I have never seen a coil mess up and partially work. They either work or not. Did you get the issue fixed with the coil.
Old Sep 12, 2010
Mad Dog Tannen's Avatar
Re: Hard start
I agree, nothing wrong with aftermarket parts.
Old Sep 13, 2010
zrock's Avatar
Re: Hard start
Napa was closed today so won't have a new coil until tomorow. Still trying to figure why it went. Only thing i can figure at this point is the kid likes to crank the sterio while she is outside. wondering if she turned the key to far and actually had the ignition powered up and just overheated it?
Old Sep 13, 2010
zrock's Avatar
Re: Hard start
Ok iv now rulled out the coil. New one and it runs no better. Replaced dist cap and rotor while i was at it. Now im thinking fuel or air? Pulled the 4 brand new plugs and 3 out of 4 were carboned up after about 5 min of running. Now im curious on how the air is controlled. I noticed that the flap on the intake dosent move when i start it untill i hit the gas to move it? I know on my prevous veh it had a controll that controlled it at idle? Im frigging stumped on this one. For one im not used to working on something with suck tight places to work or so short. I drive lifted trucks ...hehe...
Old Sep 14, 2010
Re: Hard start
I still say firing order. 1-3-4-2, No.1 is at 7:30 position. Just my .02
Old Sep 14, 2010
zrock's Avatar
Re: Hard start
You nailed it.... after searching the net again i found a good pic that was a little better than what i had found I had 2 and 4 reversed... thanks
here is the pic i found... it was the color pic that straitened it out for me
http://www.honda-tech.com/showthread...2323743&page=2
Old Sep 14, 2010
Re: Hard start
Good to hear you got it all fixed!
Old Sep 14, 2010
zrock's Avatar
Re: Hard start
hehe ya pretty stupid on my part i know better. Instead of working clockwise on the dist i was working left to right. so no mater how many times i read the firing order it seamed right to me. But i guess this is why we have fourms like this. eventually someone will say the same thing enough times to make you look at it again and get it through the thick head that they screwed up..haha
Thanks
Old Sep 14, 2010
Re: Hard start
Some times it just takes a different point of view. We all have brain farts! lol
Old Sep 14, 2010
Low and slow!
Re: Hard start
If you needed the firing order you should have asked me man lol. I have posted this picture on here a couple of times.
CarStuff
Dec 6, 2020 12:52 PM
jbradley4809
Apr 7, 2017 04:23 AM
MamaBear2015
May 3, 2015 02:17 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
black2k1vtec
Dec 6, 2001 09:49 PM
