1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
93 civic dx hatchback BIG problem HELP!!
Old Aug 23, 2010
p3anutboi's Avatar
p3anutboi is an unknown quantity at this point
Unhappy 93 civic dx hatchback BIG problem HELP!!
hey i have a 93 hatch dx automatic running like crap i got kid on the way and im on highways alot i need fixed but i wanna find problem first ok heres the situation
-Bad gas mileage
-engine running rich "black smoke through idle and drive"
-rough idle and reverse
-VERY slow acceleration
-doesnt want to go above 60 mph when push gas pedal down harder car sounds like its reving
-there are holes in the exhaust
-gas smell from exhaust
-when the car warms up it stalls in reverse
-overheats when idling for more then 5 mins
the things ive done to the car is new oxygen sensor'new air intake with new filter
clean the fuel injectors'new spark plugs'oil change'brand new tires'new muffler.
the cel does not light up when i turn the key "not turning the car on" maybe the prev owner took light out
here are the pics of spark plugs
http://i537.photobucket.com/albums/f...e/DSC08134.jpg
http://i537.photobucket.com/albums/f...e/DSC08133.jpg
http://i537.photobucket.com/albums/f...e/DSC08136.jpg
if anyone could help that would be nice =) ty
Old Sep 28, 2010
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
Re: 93 civic dx hatchback BIG problem HELP!!
first of all you have a valve pan leak from the seals around the spark plug chambers. oil soaked plugs are a giveaway. second they are probably fouled. overheating sounds like a bad water pump to be honest, and they are known to go out, be sure if you replace it to change the timing belt with it. If its sounding like its revving when you stable the rpms say at like 3k, and the needle is bouncing, it is 9 times out of 10 the iacv, could also be a vacuum leak so have someone run a vac test on it. The gas smell from the exhaust means its running rich somewhere, which can be caused by a vacuum leak to be honest with you. It could also explain the stalling and lack of acceleration as well. It will also cause your gas milage to suck royally. So thats what ive got for you i hope some of what ive babbled about is useful, good luck.
Old Sep 28, 2010
"goose"Jay's Avatar
oh and just because the injectors have been cleaned doesnt mean they are working properly....i found this out myself. also if you have any check engine lights that would be of big help as well.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
