1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 Civic The Case of The Disappearing Coolant
Old Aug 19, 2010
delliott101's Avatar
delliott101 is an unknown quantity at this point
I am helping my stepson with his '95 Civic. It is a California salvage vehicle and looks like it was in a front end accident at one time.
For some reason the coolant drains out of his radiator. For example, he told me that he filled it with water 2 days ago, but when I checked yesterday I had to fill it with about a third of a gallon of water. I ran the engine (idle and a short drive to the gas station) and I am not seeing any leaks. Hoses all look good. Fan runs fine. The gauge is reading on the cool side, almost half way between cold and hot.
I'm not sure if it is a water pump problem or head gasket. Fan works, nothing leaks.. no water found anywhere. The coolant disappears. I have him driving the car right now on his errands and will check everything when he gets home.
Any suggestions as to what else to look for?
Old Aug 19, 2010
lazlong's Avatar
Re: 1995 Civic The Case of The Disappearing Coolant
Sounds like the headgasket.
Old Aug 19, 2010
No water in the oil... not that I could find... isn't that a symptom of a blown head gasket?
Old Aug 19, 2010
02civicsi02's Avatar
Low and slow!
It does sound kinda like the head gasket. And if there is bits of stuff on the dipstick that can tell you that its the head gasket. Another way is to check the o2 sensors to see if there is any wear on it from coolant. The o2 sensor will be like white and this could tell you that it is a bad head gasket.
Old Aug 19, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
White rings on the underside of the oil cap is another clear sign of head gasket issues.
Old Aug 19, 2010
Well, here's what I found so far...
I looked at the head area and there was a bolt missing. I'm assuming this was causing coolant to get into the combustion chamber and burning it off. No leaks found and nothing in the oil (thankfully).
I found a bolt to put in (10mm head and I have plenty from my air-cooled VWs). The bolt fit and it's good and snug. I also tightened the other bolts, as they were a little looser than they should have been (not too loose, but not snug either).
I changed the plugs... I'm having my stepson keep an eye on things as he drives it.
Old Aug 19, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
I when I read the title.
Good title!
Old Aug 19, 2010
Good title!
Thanks I wanted to make it stand out a bit!
Xuhme
21
Aug 7, 2023 03:40 PM
bsmiley
Apr 27, 2015 01:27 PM
mrohitredd
Apr 15, 2015 08:13 PM
deus-ex
Apr 13, 2015 12:29 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
