Heater broken after AC treatment
Old Aug 14, 2010
spaniel74's Avatar
spaniel74 is an unknown quantity at this point
Hi all,
I have a Honda civic 1.6 2001 executive. Recently the heater stopped working - the fans can only blow cold air and it's a pain getting rid of mist on the windscreen.
Just before it happened I bought one of those antimicrobial spray canisters and put it through the air-con as per instructions. You think I might have shorted something? I wondered if it might be a blown fuse.
Suggestions welcome - thanks!
Old Aug 22, 2010
electric130's Avatar
Re: Heater broken after AC treatment
check your anti freeze level in the radiator.
Old Aug 28, 2010
spaniel74's Avatar
have topped up the coolant - problem still there. Further reading on this suggest it has nothing to do with the electrics - apologies for mis-posting here
Old Aug 28, 2010
where you do it? radiator or expansion tank?
Old Aug 29, 2010
spaniel74's Avatar
I topped up the expansion tank. After some reading, I checked the pipes leading to and from the radiator. The top pipe that feeds coolant to the radiator is hot but the bottom one that takes coolant away is cool. You think I may have a blockage? If so, what's the best way of getting rid of it?
Old Aug 29, 2010
you need make sure the radiator's topped off, not just the expansion tank. so take the radiator cap off when it's cool and fill it up there. if there's too much air in the radiator, it's hard for it to pull from the expansion tank. this was my experience anyway.
h4ldol
Apr 24, 2017 08:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Crazygrlinak
Oct 8, 2015 05:06 PM
cferry7
Oct 3, 2015 04:33 PM
hatch90
Sep 3, 2015 08:45 AM
