1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Oil on my Spark Plugs
Old Jul 5, 2010
TINOO's Avatar
TINOO is an unknown quantity at this point
So i took out the spark plugs and noticed that 2 of the 4 spark plugs had oil on them. the car dies when i drive it sometimes. is it because of that? Anyone have any ideas? i was told to replace the valve cover gaskets and the o rings. correct? someone help me out, thanks.
It's a EG6 btw. 92 si.
Old Jul 6, 2010
chris97hds's Avatar
chris97hds is an unknown quantity at this point
Re: Oil on my Spark Plugs
That is true, the valve cover gasket and spark plug O-rings need replacement. But i don't think it is casue to make your car die while driving. Is the check engine light on? If yes, have your car scan for codes. If not, try checking the ignition switch, it is a common problem with honda cars.
Old Jul 7, 2010
neil vtec's Avatar
neil vtec is an unknown quantity at this point
if the tip of ur plugs have oil on the ur piston rings are woren am ur valve stems oil seat an guide are ****
Old Jul 10, 2010
TINOO's Avatar
no engine light is on, and only 2 of the 4 spark plugs has oil on them. a friend told me it was just because of the o rings.
Old Jul 10, 2010
annamoore's Avatar
annamoore is an unknown quantity at this point
my car has oil in the spark plug tubes sometimes to. sometimes it just one other times its 2 of them. a guy told me that i needed to change the tubes, so i have no idea. he said they sold a kit. would that fix it? and no my check engine light is not on ether.
Old Jul 17, 2010
zccivic's Avatar
zccivic is an unknown quantity at this point
i take it the oil is on the ceramic portion of the plug that doesnt go in the cylinder, yea it is the o rings for the valve cover if thats the case, your car may be running rough because of the problem, especialy if your plug wires are old, oil deteriorates the rubber
Old Jul 18, 2010
ralph50's Avatar
ralph50 is an unknown quantity at this point
It could be a couple of things.
You could have alot of blowby coming from the cylinders which means your rings are worn. The only way to check for this is by doing a compression or leak down test.
Your valve guides and/or valves seals are worn and leak oil in the compression chamber.
These are the only two way oil can get in the combustion chamber.
Hold on you didn't mention which part of the plugs as zzcivic said????
Old Jul 18, 2010
annamoore's Avatar
on my car sometimes the whole plug has oil on it. sometimes theres oil in the tube aswell.
Old Aug 8, 2010
zccivic's Avatar
ok, there are 2 portions of the plug, the part that sticks into the cyl (the elctrode and ground tab) and the ceramic portion that the plug wire attatches to, if the part that thae wire attatches to, and the threads have oil on it the valve cover gasket "O" rings need to be replaced, if u have oil on the electrode part, the problem is much worse, it is either valve guide seals, the valveguides themselves, or the rings
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
