Steering wheel shakes over bumps
Sup everyone
i drive a 02 civic...the steering wheel shakes bad when going over little consistent bumps...i know its not my tires because if the road is smooth, the steering wheel is fine at all speed.
can it be my struts are bad? and need alignment?
tires have only 4k on em
I'm bigger than you.
Re: Steering wheel shakes over bumps
Probably the struts. Just had mine replaced and that all went away. Could be your brake rotors though if this is happening in conjunction with you braking on a bumpy surface. You'll need an alignment after the strut replacement btw.
OptimisticWay
46
Oct 15, 2015 02:16 PM
breanna_17
Jul 21, 2015 04:01 PM
