Steering wheel shakes over bumps
Old Jun 24, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
Sup everyone
i drive a 02 civic...the steering wheel shakes bad when going over little consistent bumps...i know its not my tires because if the road is smooth, the steering wheel is fine at all speed.
can it be my struts are bad? and need alignment?
tires have only 4k on em
Old Jun 26, 2010
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
Re: Steering wheel shakes over bumps
Probably the struts. Just had mine replaced and that all went away. Could be your brake rotors though if this is happening in conjunction with you braking on a bumpy surface. You'll need an alignment after the strut replacement btw.
Old Jun 27, 2010
braking is fine.. just going over like a lot of bumps at once...like on the hwy or something...little bumps
shakes real bad
Old Jun 27, 2010
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Check the control arm bushings while you are under there.
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
breanna_17
Jul 21, 2015 04:01 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
