8th Gen 2006 - 2011.
07 civic problem
Old Jun 23, 2010
arkitek's Avatar
arkitek is an unknown quantity at this point
07 civic problem
I have an 07 civic ex sedan factory audio system non nav. My front door speakers stop working all together first the passenger then a month later the drivers side. All of my other speakers work fine. Any help would be great
Old Jun 24, 2010
02civicsi02's Avatar
Low and slow!
Re: 07 civic problem
Either a wiring issue or you blew them. Have you had the stereo up loud?
Old Jun 26, 2010
arkitek's Avatar
Hell yeah
Old Jun 26, 2010
arkitek's Avatar
I forgot to add this but it came back 2 or 3 times for about an hour each time
Old Jun 27, 2010
Low and slow!
Just check to see if the speakers are blown and if not then there is probably a wiring issue somewhere.
Old Jun 27, 2010
johng35's Avatar
johng35 is an unknown quantity at this point
I am thinking short in a wire or a loose wire at a speaker terminal ... expecially if it comes and goes. Corrosion at the speaker terminal ?
If it was dead then maybe blown speakers.
Even some blown speakers can issue a hiss or hum sometimes , may be very low to hear and independant of volume control.
I think if there was a blown fuse you would loose the whole unit or if this was the AMP fuse you would loose the rear speakers . Not sure if the amp has it's own fuse though, and the amp is on the optional 300W speaker system.
I do not think the fronts have their own fuses.
Old Jun 27, 2010
arkitek's Avatar
I want to thank you all for your help I think I'm gonna do the speaker upgrade and rewire. It's funny cause before this happened I was thinking about upgrading the front and rear speakers.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
